    Anzelmas's Avatar
    Stockholm, Sweden
    Default VW Golf 1.6 2010.12 need to fix immo
    Hi, m8s!
    Car is starting and running, no problems.
    ECU has no fault codes, immobilizer has two fault codes: 9456896 - Incorrect Key Programming B104D and 9456681 - Key B104C. On odometer it has running word IMMOBILIZER.
    It looks like somebody have changed the instruments cluster: VIN in it is not the same as the car has.
    At first I was thinking that there was Immo Off done. But the ECU wasn't taken out and opened. Maybe somebody managed to do immo off through OBD, but I have checked all my diagnostic boxes and haven't found the reading of this ECU by OBD.
    How can I pair everything in this car? Customer wants to have no messages on cluster.
    Cluster:
    Magnetti Marelli 5K0920861
    ECU:
    Siemens Continental Simos 7PP2 5WP40779 06A906033MH
    Jun 2013
    You can cut an empty key shell. Or remove the blade, from the key. To make a test.
    FLEX does much by OBD these days.
    Anzelmas's Avatar
    Stockholm, Sweden
    FLEX doesn't has this ECU claimed.
    Anzelmas's Avatar
    Stockholm, Sweden
    Nobody can help me?
    Mar 2011
    Romania
    same problem there , he found a solution ...
    https://forums.ross-tech.com/showthr...arelli-cluster
  6. The Following 3 Users Say Thank You to mike870 For This Useful Post:
    Anzelmas (3rd November, 2019), mobinec (1st November, 2019), thayer201 (1st November, 2019)
    Anzelmas's Avatar
    Stockholm, Sweden
    mike870 Seems it is the way to fix my problem
