Results 1 to 15 of 16
Thread: Vectra C 2002
    Jan 2019
    Default Vectra C 2002
    hi
    I am dealing with a vectra c from 2002 y20dth engine, car did not start, just a weird yellow badge and got a lot of errors, I think that is IMMO, also remote control not working when I open/close the car. Reveloprog is the cheapest solution to retrieve immo pin from my cluster ? if I buy an donor Immo can I breed it with my ecu using opcom ? Also key learning and chip programming can be done for this car using opcom ?
    bank's Avatar
    Feb 2017
    Ukraine
    Vectyra C works with CIM. but not Immo.
    Immo is a part of CIM in Vectra C.
    Go to car repair station to solve problem.
    Also, Delphi is not so good for Opel.
    Use OPcom, Tech2 or MDI
  3. The Following User Says Thank You to bank For This Useful Post:
    rafal (5th November, 2019)
    Jan 2019
    I own opcom 1.99, so I need to change Cim to work ? I cannot just buy immo from a donor car ?
    Do you have some programming procedures ?
    With carprog 8.21 can I save a dump of immo to find out the pin ?
    Apr 2014
    Spain
    Hi. Vectra C from 2002 y20dth engine have Pump PSG16. With CarProg you can find PIN code by OBD CAN comunicacion.
    Regards.
    Don't forget to press the THANKS & REPUTATION button for help in the future.
  6. The Following User Says Thank You to danielif For This Useful Post:
    Andr33iy98 (8th December, 2019)
    Jan 2019
    Cim does not have another pin ?
  8. #6
    bank's Avatar
    Feb 2017
    Ukraine
    Quote Originally Posted by Andr33iy98 View Post
    original CIM have the same CIM as original ECU
    CIM from donor will have another pin
  9. #7
    Jan 2019
    Carprog 8.21 can do this ? Read pin from psg16 ? It is all I need ? Should I buy CIM+Donor transponders or just CIM ? If I use opcom can I get this work done ?
  10. #8
    Jan 2019
    Do you have a tutorial ?
  11. #9
    Jan 2019
    And how to find Pin code for donor CIM ?
    Reveprog can do this ? I own just carprog and opcom
  12. #10
    brend's Avatar
    Oct 2015
    Same where
    2 sulutions for this.
    1.read and load dump!...from dump 100% correct pin!!!
    2.read from donor cim obd2 away vin and diller,but if vin is changed in donor cim pin from diller not work?
    So....choose!!!
  13. The Following User Says Thank You to brend For This Useful Post:
  14. #11
    Jan 2019
    So Reveloprog can do this dump read ? i DO NOT GET IT at point 2, what is diller ?
  15. #12
    Jan 2019
    Quote Originally Posted by brend View Post
    So....choose!!!
    Caprog can do this via 0BD ?
  16. #13
    brend's Avatar
    Oct 2015
    Same where
    It's mean when you get from cim obd2 away vin and with this vin drive to diller for get login vin away!!!
    Open cim look what in side and check options in reveloprog ,only that's away you can know!!!
  17. #14
    Jan 2019
    Still do not get it
  18. #15
    rafal's Avatar
    UK - PL
    Still do not get it
    Give this car for someone who will know what to do....1 hour of job and car will come back on the road
    need help
    now my goal is to buy xp-005
    who will help?
  19. The Following 3 Users Say Thank You to rafal For This Useful Post:
    brend (5th November, 2019), danielif (18th November, 2019), rokibar (6th November, 2019)
