The T300 and SBB can do it
Love this forum
paulsta (1st November, 2019)
sbb can t. t 300 yes u can generate tp with tango or buy from remkeys
is it right you can use old transponder on this vehicle and apart from tango what other tool can precode id8E Chevrolet Spark 2014
tango can pre code 8E for spark
low budget tool for obd programming T300 and X100pro
for this car if you start programming you need min 2 keys to cycle
godfathertre (2nd November, 2019)
i know the tango able to precode the normal 8e chip to spark. There is any other tool than that?
I was tested with miraclone and vvdi2 both failed but later the tango did it with the very same tp
