Results 1 to 15 of 15
    Sep 2018
    Austria
    Default Ktm bench flasher
    https://www.vxdas.com/products/ktm-bench-ecu-programmer
    Hello guys, has anyone tried this tool? Edc17 without opening?
    Oct 2019
    Interesting. Alientech, autotuner and others have developed this option while ago. That would be first Chinese tool to do edc17 pinout read and write?
  3. The Following User Says Thank You to kc cars For This Useful Post:
    caja88 (4th November, 2019)
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    They cloned/craked pcmflash SW Modul71...
    And they built a scanmatik 2 pro clone as seen in this offer...
    Users write positive but also negative threads/posts about this clone combination...
    Some users write that sw/tool stop working and has to send back to seller...
    It's not related to this seller and to this link...
    It's related generally to this sw/HW combination...
  5. The Following User Says Thank You to figani For This Useful Post:
  6. #4
    Serbia
    Good tool
    10 cars successfully done without opening
  7. The Following User Says Thank You to mitin For This Useful Post:
  8. #5
    Sep 2018
    Austria
    Any of them was edc17c46?
  9. #6
    Sep 2018
    Austria
    Quote Originally Posted by figani View Post
    I put this link just for example...
    Any feedback is good, best from someone who tried it from this forum
  10. #7
    Sep 2018
    Austria
    Quote Originally Posted by mitin View Post
    Good tool
    That's good info, where did you buy it?
  11. #8
    figani's Avatar
    Feb 2018
    Quote Originally Posted by caja88 View Post
    there are many threads about this cracked SW and clone HW...
    use search function and you can read about it...
    here is one for example...
    https://www.digital-kaos.co.uk/forum...SH-china-clone
  12. The Following 2 Users Say Thank You to figani For This Useful Post:
    caja88 (4th November, 2019), Stelaras26 (9th January, 2020)
  13. #9
    Sep 2018
    Austria
    Good feedbacks, but still waiting for someone who has done edc17c46, in first place for my car needed
  14. #10
    after some use have this error:
    Unable to use selected interface (J2534: Scanmatik - SM2 USB). Check if it's connected and not in use by other applications.
    firmware scanmatik bloked and seller Livia Autoobd2 no change my interface scanmatik
  15. #11
    alfons37's Avatar
    Dont buy from http://www.fvdiobd.com/ they have not good service and bad warranty (ktm flash)..
  16. #12
    Sep 2020
    POLAND
    A great tool. Fast, simple and secure. I have made a lot of vag edc17c46. mercedes w166 edc17. volvo xc60 2017 edc17. Never any trouble. write cheksum, everything ok.
  17. #13
    figani's Avatar
    Feb 2018
    Quote Originally Posted by motochip View Post
    uffffff...
    really a big uffffffffff from my side...
    a big uffffffffff again...
    even the ori has checksum and Tp problems...
    how could then the clone work 100%...
  18. #14
    Oct 2016
    anyone using KTM Bench with success on Ford SID208?
    My tool works on Bosch ECU in BMW-s for example but no joy with Ford SID208.
    I can not read password. The connection diagram is from my original KTAG but KTM with Modul 53 don't make an ID. Plug the cable in to KTAG and all is OK.
    Any help woud be fine.
    UNI
  19. #15
    figani's Avatar
    Feb 2018
    Quote Originally Posted by Unichip77 View Post
    UNI
    PCMflash uses other pinout, and you have to solder also resistors...
    Make a research on PCMflash and sid208...
    On some ecu's Oleg made his own pinout and or his own connections...
    KTM is only Chinese fake...
  20. The Following User Says Thank You to figani For This Useful Post:
    stanislav georgiev (16th October, 2020)
