Results 1 to 6 of 6
Hybrid View
    Dec 2018
    USA WA
    Default VW EDC17C54 EGR DPF Add Blue OFF please
    Hello i got VW EDC17C54 all DPF sensors disconnected only one temp and one lambada connected
    Need EGR off, DPF off, Adblue off. later will need stage 2
    12 Faults Found:
    9611 - Reductant Injector Bank 1
    P2047 00 [039] - Open Circuit
    Not Confirmed - Tested Since Memory Clear
    5940 - Exhaust Pressure Control Valve
    P0475 00 [039] - Electrical Malfunction
    5929 - Sensor for Exhaust Flap
    P048E 00 [039] - Short to Plus
    9764 - Exhaust Pressure Sensor 1
    P0470 00 [039] - Malfunction
    5253 - Diesel Particle Filter; Differential Pressure Sensor
    P2452 00 [039] - Elect. Malfunction
    18615 - No Communication with NOx Sensor 1 Bank 1
    U1006 00 [039] - -
    [NOX Sensor 1 Bank 1No communication]
    15706 - Exhaust Gas Temp Sensor; Bank 1 Sensor 2
    P2031 00 [167] - Electrical Malfunction
    MIL ON - Not Confirmed - Tested Since Memory Clear
    9829 - Exhaust Gas Temperature Sensor; B1 S3
    P242A 00 [167] - Malfunction
    4913 - Exhaust Gas Temperature Sensor 4 Bank 1
    P246E 00 [167] - Electrical Malfunction
    5257 - Exhaust Gas Temperature Sensor; B1 S3
    P242A 00 [039] - Malfunction
    5448 - Exhaust Gas Temp Sensor; Bank 1 Sensor 2
    P2031 00 [039] - Electrical Malfunction
    5258 - Exhaust Gas Temperature Sensor 4 Bank 1
    P246E 00 [039] - Electrical Malfunction
    Mar 2019
    test this...pass after th+rep...
    PUSH THANKS AND REP IF I HELPED YOU!!!!!!
  3. The Following 2 Users Say Thank You to sparkecu For This Useful Post:
    mischiatti2 (24th November, 2019), tech020 (3rd November, 2019)
    Dec 2018
    USA WA
    waiting for pass, anyone?
    Dec 2018
    USA WA
    Yes CKRA passat
  6. #5
    Dec 2018
    USA WA
    still got fans on all the time need some ones help please.
    any one else have solution for edc17c54
  7. #6
    Sep 2013
    VW CKRA Passat?
