Page 1 of 3 123 LastLast
Results 1 to 15 of 31
    Nov 2010
    Default CD73 doesn't turn on
    Alpine CD73 Professionnal , the cd does load and eject, the lights come on with driving lights but the rest of the radio doesn't work , no sound.
    I checked all the fuse, there is 12V coming to the radio
    I did not find any defects.
    Can anyone help me?
  2. The Following User Says Thank You to Repinator For This Useful Post:
    things4u2get (21st June, 2022)
  3. #2
    Aug 2019
    Johannesburg RSA
    Remove main PCB and turn it over. Look for 5V rail pico fuse. Its by the emitter of Q821 and is marked with a M. Its open circuit - replace. You can check the one on the 8V rail too. Its on the emitter of Q823.
  4. The Following 14 Users Say Thank You to MrRepair For This Useful Post:
    Decode Ghost (2nd July, 2020), Dr Alex (7th November, 2020), dragan68 (28th March, 2025), electro10 (19th January, 2022), ilen (5th November, 2019), irfa (5th November, 2019), Jaca77 (3rd April, 2023), kostelectronics (2nd November, 2021), Kriootron (27th July, 2020), mactoufik (9th February, 2022), marian38 (16th February, 2023), maxiperez (25th January, 2022), Sarkan (11th June, 2020), yakuzi (7th October, 2024)
  5. #3
    Nov 2010
    Quote Originally Posted by MrRepair View Post
    you were right,5v pico fuse damage.
    this radio starts on the table,or just on the car?
    Thanks!
  6. #4
    Aug 2019
    Johannesburg RSA
    You can test everything on the bench. If you get no sound the car may have an amplifier.
  7. The Following User Says Thank You to MrRepair For This Useful Post:
  8. #5
    Nov 2010
    After I deleted both eeprom cd starts but the display is visible in the fog.
  9. #6
    Aug 2019
    Johannesburg RSA
    Both IC512 & IC603 must be loaded. You have deleted the setup data. Can you restore the original or copy from another unit ?
  10. #7
    Nov 2010
    I have the original data, but it doesn't start with them
  11. #8
    Aug 2019
    Johannesburg RSA
    Try these: BMW.rar
  12. The Following 7 Users Say Thank You to MrRepair For This Useful Post:
    BUTTOLLUCIANO (26th December, 2022), Decode Ghost (2nd July, 2020), mactoufik (9th February, 2022), maxiperez (25th January, 2022), rtv (4th October, 2023), TERNOCOD (6th November, 2019), things4u2get (21st June, 2022)
  13. #9
    Nov 2010
    With your dump it works
    Thank you very much sir!
  14. #10
    Aug 2019
    Johannesburg RSA
    You can check everything in service mode:
    Switch radio ON.
    Within 10 seconds hold M button in for 8 seconds.
    Service menu will display.
    Navigate with + & - buttons
    Be careful not make changes you don't understand.
  15. The Following 3 Users Say Thank You to MrRepair For This Useful Post:
    Decode Ghost (2nd July, 2020), Repinator (6th November, 2019), things4u2get (21st June, 2022)
  16. #11
    Jul 2020
    Thank you MrRepair. My BMW Radio stopped working last week. It didnt power on anymore, but it was capable of inserting and exiting CD's. I tried your advice with Q821 and i found an smd part, which was labeled with an M, but was 1 cm away from Q821. I tested the "M" part with an multimeter and it worked, so this part wasn't damaged. After a while i saw a part with the lable "F" next to the Q821, when i tested that one, there was no continuity so i tried to bridge that part with a wire. After doing this my Radio started working again. So if the "M" part is not broken, it could be the "F" part. Thank you very much for your advice
  17. The Following User Says Thank You to ThankYou For This Useful Post:
  18. #12
    Aug 2019
    Johannesburg RSA
    You're welcome. Stay safe.
  19. #13
    Dr Alex's Avatar
    Mar 2016
    MrRepair,what amperage should i use for this fuse?
  20. #14
    Aug 2019
    Johannesburg RSA
    ******** 300 ma.
  21. #15
    May 2020
    ******** 300 ma.
    for both fuses?
    And thank you by your information, I have the same solution and was the fuse!
