hello have here a audi a4 2.0tdi 143hp 2008
sometimes when you go out for drive, the car just cranks and wont start, if you wait a little then it can start sometimes faster than other.
and sometimes you can drive 2 weeks before it happens again.
i was thinking about elv problem but all situation with elv i have is i cant get ignition on.
i have put report for vcds.
VIN: WAUZZZ8K79A023769 License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 07 08 09 0E 15 16 17 19 1E 37 42 46 47 52 53 55 56
62 72
VIN: WAUZZZ8K79A023769 Mileage: 424000km-263461miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Sporadic communication error 1000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Sporadic communication error 1000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAGA) Labels:| 03L-906-022-CAG.clb
Part No SW: 03L 906 022 B HW: 03L 906 022 B
Component: R4 2.0l TDI X01 9978
Revision: --X01---
Coding: 0104002C18072118
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM20TDI03L906022B A01022
ROD: EV_ECM20TDI03L906022.rod
VCID: 244733D42F3C8F6A99-8070
1 Fault Found:
4720 - Body Control Module (Central Electric 2)
U0141 00 [032] - No Communications
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 422742 km
Date: 2008.02.08
Time: 06:47:22
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 61 ∞C
Intake air temperature: 32 ∞C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 12.840 V
Unlearning counter according OBD: 2
Crankshaft speed (RPM): 0.0 /min
Vehicle speed: 0.00 km/h
Ambient temperature: 25.0 ∞C
Vehicle voltage terminal 30: 12840 mV
Bus Diag st Node 0-Bits 0-7: 0
Limitation: accelerator pedal: 220.0 Nm
Control Module temperature: 45.4 ∞C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AQ HW: 8K0 907 379 AQ
Component: ESP8 front H03 0210
Revision: -------- Serial number: --------------
Coding: 160D00
Shop #: WSC 06335 000 00000
VCID: 081F4764BBD44B0A95-805C
1 Fault Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 196
Mileage: 422742 km
Time Indication: 0
Date: 2008.02.08
Time: 06:47:22
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x00A2
Hex Value: 0x0016
Hex Value: 0x02A1
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 M HW: 8K0 907 064 M
Component: BCM2 1.1 H70 0134
Revision: 00002001
Coding: 030200
VCID: 3A7BEDACB5B8E99AD3-806E
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0608000007680008
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H35 0039
Serial number: 0208000019018014
No fault code found.
Address 07: Control Head Labels: Redir Fail!
Part No SW: 8T0 035 769 B HW: 4L0 035 730 B
Component: MMI Cockpit H60 0620
Revision: C61030BE Serial number: AUZ6Z3H59I5963
Coding: 0144201
Shop #: WSC 06325 000 00000
VCID: 3C77EBB47F8CD7AAC1-8068
Subsystem 1 - Part No: 8T0 919 609
Component: E0380 BedienteilH08 0100
Subsystem 2 - Serial number: 00000000081662
Subsystem 3 - Serial number: 0103.05.080000000100010282ˇ
Subsystem 4 - Serial number: 010282ˇ
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA
Component: KLIMA 1 ZONE H06 0140
Revision: A1000000 Serial number: 0109.05.080577
Coding: 34000000
VCID: 70EF0F84A34463CA2D-8024
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H21 0253
Revision: 05021001 Serial number: 00000000040494
Coding: 260050914034AF000001000300001D0D0F1C07080001010100 0000
VCID: 306FCF8463C423CA6D-8064
Subsystem 1 - Part No SW: 8K1 955 119 HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110508 H06 0060
Serial number: SWFBIE 0000523
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10125476
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Serial number: 00000000001005081293
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 196
Mileage: 422742 km
Time Indication: 0
Date: 2008.02.08
Time: 06:47:00
Address 0E: Media Player 1 Labels: Redir Fail!
Coding: 0144201
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD15HKYY
Coding: 30343434363030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_A02.rod
VCID: 3C77EBB4B78CD7AAC1-8068
Crash sensor for side airbag: driver side:
Serial number: 6334MSME2B53212CB
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME39005A4CH
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME5B33176BO
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME7049426BL
Crash sensor for front airbag: driver side:
Serial number: 63732SME71704327U
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME70683A630
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 E HW: 8K0 953 568 E
Component: Lenks.Modul H12 0013
Revision: -------- Serial number: 90315HEI000GZ
Coding: 000007
VCID: 3C77EBB4BF8CD7AAC1-8068
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 196
Mileage: 422742 km
Time Indication: 0
Date: 2008.02.08
Time: 06:47:22
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8K0 920 900 D HW: 8K0 920 900 D
Component: KOMBIINSTR. H15 0221
Revision: 00200000 Serial number: 7VM38ZG58
Coding: 0F04100003000008000000
VCID: 2B55D8E84AE2401258-807E
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 196
Mileage: 422742 km
Time Indication: 0
Date: 2008.02.08
Time: 06:47:24
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8T0 907 468 K HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0092
Revision: EB302042 Serial number: 4200E0850280A5
Coding: 000303
VCID: 49998260E05E72024A-801C
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 18019865250408
2 Faults Found:
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 196
Mileage: 422742 km
Time Indication: 0
Date: 2008.02.08
Time: 06:47:23
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 196
Mileage: 422742 km
Time Indication: 0
Date: 2008.02.08
Time: 06:47:23
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 8T1 035 110 C HW: 8T1 035 110 C
Component: MP3-Changer H41 0390
Revision: 00041001 Serial number: AUZ5ZBH8414120
Shop #: WSC 00000 000 00000
VCID: 2A5BDDEC8518591AA3-807E
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 196
Mileage: 422742 km
Time Indication: 0
Date: 2008.02.08
Time: 06:29:19
Address 37: Navigation Labels: Redir Fail!
Coding: 0144201
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000007163742
Coding: 011C02204000410001
VCID: 3F8D9CB8AE9ACCB2E4-806A
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 196
Mileage: 422742 km
Time Indication: 0
Date: 2008.02.08
Time: 06:29:03
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0111669940
Coding: 0100062020390040012002
Address 47: Sound System (J525) Labels:. 8T0-035-223-BAM.clb
Part No SW: 8T0 035 223 AE HW: 8T0 035 223 R
Component: DSP Basic H08 0300
Revision: S2600000
Coding: 010101
VCID: 71E90A80A84E6AC222-8024
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000007187078
VCID: 3E73E1BCA990C5BAEF-806A
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 196
Mileage: 422742 km
Time Indication: 0
Date: 2008.02.08
Time: 06:29:03
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 D HW: 8K0 907 801 D
Component: EPB Audi B8 H04 0050
Revision: 00000003 Serial number: 10000000025832
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 196
Mileage: 422742 km
Time Indication: 0
Date: 2008.02.08
Time: 06:28:59
Freeze Frame:
Voltage: 12.60 V
Count: 68
Speed: 0.0 km/h
Hex Value: 0x0263
Hex Value: 0x0001
Hex Value: 0x1010
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 06334 000 00000
VCID: 3467C39457DC1FEA09-8060
Address 56: Radio Labels: Redir Fail!
Coding: 0144201
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8K0 959 795 HW: 8K0 959 795
Component: TSG HL H06 0170
Revision: Serial number: 0000007176827
Coding: 010C02204000210001
VCID: 7F0DDCB8EE1A0CB2A4-802A
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Part No SW: 8K0 959 794 HW: 8K0 959 795
Component: TSG HR H06 0170
Revision: Serial number: 0000007149655
VCID: 7EF321BCE91005BAAF-802A
End-------------------------(Elapsed Time: 03:12)--------------------------
