Peugeot 206 marelli Iaw 48p2.72
Results 1 to 6 of 6
    Jul 2018
    7
    Downloads
    Uploads
    Default Peugeot 206 marelli Iaw 48p2.72
    hi , i have peugeot 206 with iaw 48p2.72 , i try to immo off with immo decoding but the car wont start , i have in database a file for immo off for iaw 48p2.70 the car start but the fan dont stop .
    have a solution ?
    this is my original file
    Jul 2014
    75
    Downloads
    Uploads
    Default immo off
    Try this one, dont forgot to cut f3 and f4 pins on middle conector, its best if you cut the pins from inside ecu. cheers.
    rafal's Avatar
    Jul 2010
    UK - PL
    2,529
    Downloads
    11
    Uploads
    Quote Originally Posted by goran13 View Post
    why f4?..................
    will see answer from user....................
    from 11-06-2020 I do not resend a password when someone does not care about the account
    I will never accept help from KISZKA
    even if he were the last man on earth
    jamienatorr's Avatar
    May 2018
    Poland
    52
    Downloads
    Uploads
    if this model is equipped with air conditioning it will stop working after immo off - tested.
    Nov 2016
    147
    Downloads
    113
    Uploads
    YEs but i did try one also but fans are always on
    Jul 2018
    7
    Downloads
    Uploads
    thanks i try the file , the car start but the fan is always on
