Results 1 to 5 of 5
    Oct 2013
    Default New Panda 8f3 Km correction
    hello,
    i need to correct km value on Marelli 8f3.p8 ecu of Fiat New Panda 2013
    i need correction of odometer, last oil change,last dpf regeneration and other value...
    in attached dump of 95640
    current value: around 220000km, i need 120000km
    thanks in advance!
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Is it so difficult to write here the exact original mileage?
    Oct 2013
    with diag 215490km
    156alfa's Avatar
    Feb 2012
    greetings from italy
    Hello friend
    here is your perfekt file
    I made your file because I know
    well the coding, but the next time the same
    who if it does not put a photo with the response of a suitable tester
    nothing will be done
    Try and repost
    Greetings from Italy
  5. The Following 2 Users Say Thank You to 156alfa For This Useful Post:
    jomberykaso (9th November, 2019), Rebound (9th November, 2019)
    Oct 2013
    The dump works, thanks !!!
