Results 1 to 12 of 12
    Jun 2016
    Default Volvo v50 immo problem
    The car is Volvo v50 2005year 2.0D
    After repairing the steering column lock module the car doesnt start.
    On the dash there is an Immo error.
    The immo ecu has errors:
    6C47 - control unit steering column locking, incorrect signal
    6C53 - Control unit steering column locking, internal
    The engine ecu has no faults.
    The battery was changed with a new one while the module was beeing repaired.
    Now the steering module has no power.
    Is it possible ECU and CEM to have lost sync and thats why there is no power to the steering module?
    brend's Avatar
    Oct 2015
    Same where
    NB!!! Don't ask in PM old file password , Im not remember.
    Jun 2016
    Could that be the reason there is no power to it?
    Power to the lock module comes from the CEM.
    My question is if the engine ecu and CEM lost sync, can that be the reason for the CEM not to send 12V to the lock?
    brend's Avatar
    Oct 2015
    Same where
    waldi1979's Avatar
    Dec 2010
    The power come from CEM just for a moment, when the steering lock is opened or closed.
    Probably you know it but I remind you.
    Jun 2016
    Yes it does come for a second.The LIN has signal too.I tried the car again and got a new error in the engine ecu - C326. So i guess now this confirms that i have to sync engine ecu and CEM.
    Jun 2016
    Does anyone know if a second hand steering lock module needs adaptation
    Aug 2015
    if you not done what is written in post2 . the car will not start.
    Jun 2016
    Problem was solved, the SCL was removed from the software.
    Sep 2009
    Hungary
    Quote Originally Posted by Nqkaf View Post
    How did you do it? Which program did you use? Did you modify the CEM or the ECU? I have the same problem and I am going crayz slowly ...
  11. #11
    Top Poster + aHmEX's Avatar
    May 2011
    Istanbul
    hello dear,
    i have same problem on S40, can you help me ? if i send to you scl file and cem file with payment
    Everything about the auto key
  12. #12
    MartiLer's Avatar
    Dec 2016
    where are the dumps? aHmEX has exceeded their stored private messages quota and cannot accept further messages until they clear some space
