can you not read the isn from the dme with your tool
jamesfawcett (14th November, 2019)
jamesfawcett (15th November, 2019)
My CGDI has finally arrived!
It took a while to activate, but I now have all the activations available.
Last edited by jamesfawcett; 2nd August, 2021 at 11:16 AM. Reason: ISN removed (It was just a 4 digit code)
Thanks all fixed!
Thanks!
Thanks Removed dumps
Last edited by jamesfawcett; 2nd August, 2021 at 11:17 AM. Reason: Removed dumps - they were encrypted anyway :)
Original CAS
Mileage:70468
ISN 16Byte FFFFFFFF.....
ISN 4 Byte FFFF
CAS Dump
Mileage:0
ISN 4Byte FFFF
DME / DDE E Series 4 digita:
D62M57A0, D62M57B0, D60PSA0, D50M57A0, D50M57E1, D60M47A0, D60M57A0, MEV9N46L, ME9N45, ME9N62, ME9E65_6, N73_L0, N73_R0, ME9N62_2, MSV70, MS450DS0, N62_TUE, N62_TUE2.
DME /DDE E Series long ISN (SK):
MSV80, MSD80, MSD81, MSD85, MSD85Y, MSS60, MEVD176K, ME17N45, MED17_2, MED17_2N, MEV17_2, MEV17N46, MEVD174K, MEVD174KW, MV1722, MVD1722, MEVD172, MEVD1724, MEVD1725, MEVD172Y, MEVD17KW, D70N47A0, D70N47B0, D71N47A0, D71N47B0, D71N47C0, D71N47D0, D72N47A0, D72N47B0, D73N47A0, D73N57A0, D73N57B0, D73N57C0, D73N57D0.
I don't know why everytime I swap CAS and re-write the dump, it will start just once.
Last edited by jamesfawcett; 2nd August, 2021 at 11:20 AM. Reason: I said bad things about CGDI, but infact it was my battery voltage
Brother, it seems like you've taken this massive journey to do AKL very far.
You have VVDI2, it's simple. RESTORE original dump to CQS. Choose "file make key" option and tick the box 16 or 64 attempts to start.
Program the key with programmer and try starting. When it doesn't , put key in programmer and click the window where it says "not start". After a few attempts it'll fire up. Done.
If you try doing the same with OBD the tool will mess up your CAS eeprom which happened to me. Car will start once but then you'll have a A0AA code in CAS.
jamesfawcett (28th November, 2019)
Thanks I all sorted
