Results 1 to 15 of 27
    odyseus7's Avatar
    GREECE
    Default vag com 805 read atmega
    Hi,i try to read atmega 162 with upa but i cant.Anyone know something?i want to repair my 805 vagcom.thanks
    K.Kambelovac Croatia
    Pony Prog read atmega 162
    This is pictures
    Norway
    Try this. Worked for my 6 dead cables
    http://www.digital-kaos.co.uk/forums...75/#post323334
    BR
    KP
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    UPA USB will program ATMEGA from VCDS cable without a problem.
    Program eeprom
    Program flash
    Program Lock bits
    Program Fuse bits and you are done.
    Hello, I have always used this program.
    USB jack connects to a computer powered obd socket (pin 4 pin 5 gnd 16 12volt)
    and launches the program.
    I am trying to fix some old VAG COM 704.1 and a VAG COM 805 I got back from my customers.
    I know what cables are really 704.1 between them, but I suspect someone gave me back a broken VAG COM 704.1 as he told me it was 805.
    In the meantime I bought some 805.0, and then much more 805.1 which have a label on the plastic body, and the mainboard looks different. Much different.
    So I have 3 types of board in front of me now !!! I am confused.
    I look the 805 (or supposed to be 805) and looks different than my 805.1
    So I am not sure if it's really 805.0, Is there any way to fnd what it could be with security?
    Sep 2010
    lack of access! ???
    how to access this link: http://www.digital-kaos.co.uk/forums...75/ # post323334
    Newbie azazell's Avatar
    Sep 2008
    Romania
    i think u must post more stuf and after that u can` see more..
    https://t.me/pump_upp
    Quote Originally Posted by tadzik View Post
    lack of access! ???
    garage section have some change and some thread are deleted....
    go here...
    http://www.digital-kaos.co.uk/forums...rything-99750/
    Feb 2009
    Quote Originally Posted by bnad3m View Post
    go here...
    thank you.you are a nice guys!!
  13. #13
    Quote Originally Posted by chippendelu View Post
    are you blind m8!... read post #10
  15. #15
    Oct 2010
    hi how can access more links.sorry but i am new here
