I realy need help. Im 200km far from home
Many many THANX. I try and report back
if not working try 0883, or simply read with inpa
im far from workshop and try using what i have. Inpa is 200km from here
adiagnostyka (10th November, 2019)
adiagnostyka (10th November, 2019), ricked (17th December, 2020)
08ac and 0883 not work now i try 2719. urametz send me pm. Many thanks for help
2179 - also wrong isn
would be interesting to see what inpa says...
maby some tested file e34 540 with knowing isn ??
ok, this is interesting, same car here, 4 years ago... someone was there before you
https://www.digital-kaos.co.uk/forum...03484-need-isn
Yes, I was wrong, these 4 digits must be converted to hex. And I think that "mislav88" was closer to the truth. The last three digits _x883 that he gave, I think are true, the first mystery. You can try sorting from 0 to F. I have a dump with a well-known ISN but another software and location but the code structure is the same. Here is the dump, its ISN 03A9.
Although if you count 2179 in your dump into a hex, it turns out 0883. It's interesting to figure it out.
It’s a pity that now I’m not at work, there I have a base with old BMW dumps and well-known ISN. Probably found from a block like yours with a well-known ISN.
