I am actually trying to understand the map-structure of EDC16U1 from VW T5 AXE-Engine.
it is this ECU: 070906016AP
I was able to identify plenty of maps, but I do not understand what the maps on the following locations do:
DDFDE Torque Limiter?
DFF94 is it smoke limiter?
E0350
E5D80
EC740
EC834
EC928
ECA1C
D35CA
Where is SOI Maps?
I qould be really nice, if somebody could point me into the next direction.
File is attached
Greetings,
Yogi
Real engines don't need forced induction
Who needs a turbo when you have a stupidly quick naturally aspirated engine?
cocktailyogi (11th November, 2019)
For the record:
E5D80- InjCrv_phiMI1HCDes_MAP- Main SOI during PoI2HC
EC740- PCR_pBDesRgn1a_MAP- Boost Setpoint A during DPF Regeneration
EC834- PCR_pBDesRgn1b_MAP-...
EC928- PCR_pBDesRgn2a_MAP-...
ECA1C- PCR_pBDesRgn2b_MAP-...
D35CA-AirCtl_mDesBase_MAP- EGR base map
Okay, you got me....
I have no idea, what the map "E5D80- InjCrv_phiMI1HCDes_MAP- Main SOI during PoI2HC" is doing.
I can see, it comes after the SOI-Map-Sequence and behind Start-Correction-Maps.
Kind regards,
Yogi
Reference angle for calculation of Post injection SOI based off Main SOI.
Don't worry about it- it's pretty useless for your needs but you did ask about it...
Okay, thx for your patience.
Now I am interested. Is Post injection only for DPF regen or also during normal operation on a non-DPF-engine?
bye
As far as I'm aware no DPF= no post injection.
cocktailyogi (13th November, 2019)
