You need to read dash processor 9s12 and to try to be more active in this forum.
wersu (12th November, 2019)
ok... so the only way is to open the dash ?
many tools can read it via obd port , even some clone fvdi , carprog ...
wersu (18th November, 2019)
can you give me a tip which obd is working 100 % for small price ?
thanks for info
Thanks,
it is working with fvdi clone...now i have both log in...
now what are the next steps to do , to change the dashs ? 8j0920930C to 8j0920930Q
is it working with vcds ? or with fvdi clone too ?
must i learning my car keys too ?
can somebody help me ?
point to point ?
With the old dash read immo in the car via obd. Put in the new dash and use the all keys lost option on he new dash. When asked to create new keys just import old IMMO to the dash and you are done . You will still need the radio code but that is somethng different. After this recods ABS (save current coding before putting in new dash) and you are done.
wersu (20th November, 2019)
hello DjDvr,
thank you very much for the answer... i have the radiocode for my rns-e...
so i do not need to learn my car key new correct ?
now i wait for my dash , it is on the postway to me...
now i have the new(used) dash but without pincode …
what can i do ? the seller give me no answer…
is there a way to read the Login of this vdo 8j290390Q ? which tool i can do this ?
at the moment there is" safe "on the dash and car not starting.
i have readout the eeprom with ch341A flasher
but how can i readout the Flash Dump 3217G ? not working with svci 2018...
thanks for helping...
you need to get a real programmer mate
thank you for the answers...
is it possible with xprog v5.55 ?
i have read out the immo data from my original dash 8J0920930C 2007 with svci2018 clone.
but it doesn‘t write it to my new (used)dash 8J0920930Q 2009...
if i want to read the immo data from the new dash with svci 2018 there are no correct informations inside...
i need flash 3217g Dump 8J0920930Q 2009 … and eeprom Dump …
i have done something with xprog v5.5.5 clone and now my dash does Nothing...
please help with Dumps ...
the problem is i have no original dump ... i have forgotten the do a backup and now there is an wrong 3217 dump in my dash...
so i need a flash dump for my 8j0290390Q ... at the moment i drive with my original dash...
flashing is working with my xprog v5.5.5. but i do this with wrong file ...
thanks for helping... i want the white hand dash ...
