Results 1 to 12 of 12
    Oct 2019
    Default Bmw 9402 error Rollover controller internal fault
    I read the code using carProg but not sure if this is the full code, maybe someone can pitch it. Ill attach the dump I was able to recover if someone can rewrite the correct one without errors.
    Part Number is: 65779134734-01
    chip: 95080
    Oct 2019
    Still trying to convert .bin file to .rar
    As soon as i figure out why the file is invalid ill post an attachment of the file. Thank you in advance to who can help me
    ateyourv8's Avatar
    Feb 2018
    Down Yonder
    You have to use a file compressor and add your .bin file to archive.
    Right click on the .bin file, select add to archive and save.
  4. The Following User Says Thank You to ateyourv8 For This Useful Post:
    safe69 (13th November, 2019)
    Oct 2019
    Default error dump
    The attached file with error.
    Oct 2019
    Is the file I attached done correctly?
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Your repaired file ...
    Best regards.
    Dragon
  8. The Following User Says Thank You to dragon100 For This Useful Post:
    safe69 (21st November, 2019)
  9. #7
    Oct 2019
    It says i need a password. Can you send it to me in pm
  10. #8
    Oct 2019
    Any other reason I can’t unzip the attachment without password?
  11. #9
    dragon100's Avatar
    Jan 2012
    I sended pass, I told you use newest winrar to unpack ...
    Best regards.
    Dragon
  12. #10
    Oct 2019
    I might have burned the circuit board when i was putting it back together. Ended up ordering new part. Thanks for all your help. I attachment a picture, do you think that its completely ruined?
  13. #11
    Oct 2019
    Default Attachment
    So what do you think? Toss it?
  14. #12
    slick_dick's Avatar
    Essex
    no pad left .. bin it!
    “There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
  15. The Following User Says Thank You to slick_dick For This Useful Post:
    safe69 (9th December, 2019)
