Well ecusafe do it for you ... special in this ecu
I tried to deactivate egr off by hysteresis , manual, and the dpf. But when I start the car cold, the car starts to get a lot of white smoke and the idle is unstable.
I have emptied the fap, and I want to cancel the egr. But I can't do it, it's still the same.
If I unplug the egr, the car does not smoke, but the car has no power.
And mainly it happens, when the engine temperature is low.
So I think it's from the egr, or the dpf.
Please can someone help me?
Please, no volta, ecusafe, no aes.
Thanks...
alcorte
hi college test and report,egr dpf chk ok
passs pm
alcorte (12th November, 2019)
no work, the car starts to get a lot of white smoke and the idle is unstable. If I unplug egr no somke, but I have not power.
ADS, ASC, Ecusafe, Volta not working
Yes, please. Thanks advance.
your file plug disconnected.
alcorte (13th November, 2019)
I will try in a few minutes and report.
thanks. The car is same. Your file dontī work. I have two dtc p0650 and p0489.
faults is not the problem, i can remove them. you have to blank the egr and remove plug and power come back
I remove conection egr, and the car canīt power. And I have white smoke in idle.
I donīt understand " you have to blank the egr".
Can someone explain it to me in another way, or with other words.Thanks.
replace the gasket with solid sheet metal at the inlet of the EGR
alcorte (14th November, 2019)
Thank you. I've already done it. And everything remains the same. When the car is cold, when starting, it throws a lot of white smoke, I slowed unstably.
I think he starts doing regenerations.
I do not remember where I have read, that in order to eliminate the fap, a reading must be done by bdm.
Does anyone know something.
I'm almost sure that what fails is the dpf
someone please
