Results 1 to 6 of 6
    May 2019
    Default A little help from the members please Hyundai Accent 95910-1r250
    Hello fellow members I’m currently trying to read this v850 mcu using carprog but unfortunately I can’t find a diagram for this particular chip it’s not in codecard. Cpt has one pinout but I’m not sure how to invert from cpt adapter to carprog a10 adapter so that doesn’t help me. If someone can please point me to the right direction as to where can I find a pinout of this mcu to read the crash data i will be greatly appreciated. It’s a UPD70F3629 nec mcu.
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Maybe this helps you!
  3. The Following User Says Thank You to Stelaras26 For This Useful Post:
    Wilberg93 (15th November, 2019)
    May 2019
    Quote Originally Posted by Stelaras26 View Post
    With which software you do this ? I’m trying with carprog full legit
    Jan 2016
    Carprotool programmer CPT
  6. The Following User Says Thank You to freerefill For This Useful Post:
  7. #5
    May 2019
    Quote Originally Posted by freerefill View Post
    yes I know about this pinout but I am using carprog so the cables are different even the label cpt uses are different than carprog labels unless someone can tell me which cables to connect from a10 carprog to each one cpt shows on the pinout.
  8. #6
    May 2019
    i want to thank you all for the help i used stelaras26 image as a example and read perfectly fine once again thanks to everyone. i just used the labeled lettering for the connections converted them to carprog colors and bam! thank you all for the help
  9. The Following User Says Thank You to Wilberg93 For This Useful Post:
    mkopytekchi89 (10th October, 2022)
