Results 1 to 7 of 7
    Oct 2019
    Default GOLF 3 1.9SDI MSA12 Immo Off
    Hi all,
    I need to immo off a Golf 3 ECU to get the motor back to work in my VW T3. I read the dump of 93C46. Chip 1 in the picture.
    Can someone Immo off?
    regards,
    Surfer1123
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Can you read immobox ?
    Here to HELP!
    Oct 2019
    I do not have the original immo box of this ecu.
    immokill's Avatar
    Jun 2009
    UNIVERSE
    try this in both eeproms to change 96 to 00
    Here to HELP!
  5. The Following User Says Thank You to immokill For This Useful Post:
    Surfer1123 (16th November, 2019)
  6. #5
    immokill's Avatar
    Jun 2009
    UNIVERSE
    i need immo box with hco5 inside to turn immo off.
    Here some instructions for that ecu found here long time ago. But when turn immo off in immobox it must start.
    here you go some info for that ecu .
    Here to HELP!
  7. The Following User Says Thank You to immokill For This Useful Post:
    sep382 (15th July, 2020)
  8. #6
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Here to HELP!
  9. #7
    Oct 2019
    Thank you so far. Unfortunately I do not have the immo box. I try to immo off in the ECU, this works only for a moment. After a non specific time the Immo is back on. Any clues?
    I'll try to immo off in both eeproms 93c46.
    The other files I found in the search doesn't work.
