Results 1 to 8 of 8
    Default Honda Jazz No power steering
    Honda Jazz year 2002 1.2 petrol
    While running battery cable disconnect
    NOW
    vehicle is hard to steer
    fuse is ok, got voltage before and after fuse,
    there is NO VOLTAGE in power steering motor.
    What's wrong there?
    ______
    Meat-Head's Avatar
    Some retard has blown the control unit at a guess, or tge alternator
  3. The Following User Says Thank You to Meat-Head For This Useful Post:
    DiegoStud (23rd November, 2019)
    DiegoStud's Avatar
    Aug 2019
    EPS light on? Fault codes?
    Check and EPS fault codes. You will definately have one saying low voltage. Often won't run until clear
    You may have lost torque sensor programming too.
    Here's a high tech procedure you can try
    Retrieve DTCS:
    1. With the ignition switch OFF, bridge terminal # 4 and # 9 of the 16P Data Link Connector located under the dash on the driver's side.
    2. Turn the ignition switch ON.
    3. Record the DTC.
    4. The blinking frequency indicates the DTC. DTCs are indicated by a series of long and short blinks. Add the long and short blinks together to determine the DTC.
    NOTE: The system will not indicate the DTC unless these conditions
    are met:
    • Set the front wheels in the straight ahead driving position.
    • The ignition switch is turned ON.
    • The engine is stopped.
    • The SCS circuit is shorted to body ground before the ignition switch is turned ON.
    5. Turn the ignition switch OFF.
    6. Remove the jumper from the DLC.
    Clearing DTCs
    Using Service Check Signal Circuit
    1. With the ignition switch OFF, bridge terminal # 4 and # 9 of the 16P Data Link Connector located under the dash on the driver's side. With vehicle on
    ground, set front wheels in straight ahead driving position.
    2. Turn ignition switch ON. The EPS indicator comes on for about 6 seconds. Within 4
    seconds of turning the switch ON, while the EPS indicator is on, turn the steering wheel 45° to left from straight ahead driving position, and hold steering wheel in position until EPS indicator goes off.
    3. Within 4 seconds after EPS indicator goes off, return steering wheel to straight ahead
    driving position and release steering wheel. The EPS indicator comes on again 4 seconds
    after releasing steering wheel.
    4. Within 4 seconds after EPS indicator comes on, turn steering wheel 45° to left again and hold it in position. The EPS indicator goes off after 4 seconds.
    5. With in 4 seconds after EPS indicator goes off, return steering wheel to straight ahead
    driving position again and release steering wheel. The EPS indicator blinks twice 4 seconds after releasing steering wheel, indicating that DTC was released.
    NOTE: If EPS indicator does not blink twice, an error was made in the procedure and DTC was not erased. Turn ignition switch OFF, and turn ignition switch ON. The EPS indicator comes on for about 6 seconds. Within 4 seconds of turning the switch ON, while the EPS indicator is on, turn the steering wheel 45° to left from straight ahead driving position, and hold steering wheel in position until EPS indicator goes off.
    Turn ignition switch OFF after EPS indicator blinks twice. Remove jumper wire from DLC. Perform DTC code output operation, and be sure that code has been erased.
  5. The Following 2 Users Say Thank You to DiegoStud For This Useful Post:
    alessioblaupunkt (13th November, 2019), Meat-Head (12th November, 2019)
  6. #4
    Nothing. The EPS light is always off.
    Fuses ok,
    ______
    Meat-Head's Avatar
    Sounds can your computer recalibrate anything
  8. The Following User Says Thank You to Meat-Head For This Useful Post:
    alessioblaupunkt (21st November, 2019)
  9. #6
    DiegoStud's Avatar
    Aug 2019
    No light- not good.
    Time to get head under dashboard and inspect EPS control unit and relay
  10. The Following 2 Users Say Thank You to DiegoStud For This Useful Post:
    alessioblaupunkt (21st November, 2019), Meat-Head (21st November, 2019)
  11. #7
    Jul 2013
    yorkshire
    Did i read the post correctly, you checked the fuses but did you check for 12v at steering control module? You must have 12v to continue.
  12. The Following User Says Thank You to autoden For This Useful Post:
  13. #8
    I don't have the car, I'm writing for a friend, I will report in the next days. Stay tuned.
