Post dash file 24c16, maybe I could help you
Hi, I have problem with dashboard not showing mileage, trip mileage it show only ----- when you try to scrol with menu or up/down switch on turn signal lever stalk nothing hapen. When tur ignition on I have few errors. I have this insue on insignia time ago and it was corupted eeprom in BCM. I read few threads that is the same problem on cruze. I will be grateful if anyone could look at BCM file, or post any other working only to test (will then find out by trying corupted part, immo, key,...)
Chevrolet Cruze
1.6 16V
2009
LHD
manual gearbox
83kW
F16D4
BCM 13504449
Regards
test...............
pipina (13th November, 2019)
Hi, dash readout attached.
Regards
Hi, I try both but unfortunatly still the same.
Regards
you have to change the eeprom ... and place the file they sent you ...
and if it still does not work, verify that there is no welding stuck on any of the elements, that this damage appears in your BCM,
luck
Hi, BCM file is original OK. Corupted is dash file. Anyone with solution or file from other car to test.
Regards
pipina (17th November, 2019)
If no file works then with GM online programming will fix ur problem. But am sure a good dash dump will fix your problem unfortunately I dont have any GM dash dump as I work them all obd2 and only acces the BCM
Hi, I return customer car back with this file, tomorow when he arive back to the office I test and let you know.
Regards
