Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
  1. #16
    May 2018
    Ukraine
    For synchronisation needed STAR...
  2. #17
    Nov 2019
    Amazing.....
    Thank you very much. for taking his time to help me and teach me.
    Just a question to see if I'm on the right path? Should I use my ktag and write this file in the eeprom of my donor ecu right?
    I only select eeprom in ksuite? Or should I select everything?
    sorry for requesting dummies-like information
  3. #18
    Nov 2019
    update: I wrote the renew file of autodiagdoctor send me in the eeprom with ktag and executed perfectly. Thank you so much autodiagdoctor.
    then I went to the junker and got an obd2 connector and a 9.7 connector, to build a cable to connect the ecu to the bank. Connect the autel scanner and I was able to perform the coding and updating scn.
    Then I connected the ecu in the car and my surprise and happiness is that I revived. Now all the live data appeared again perfectly. Vin of donor ecu disappeared. Perform an initial star procedures whit the scan tool and was completed.
    But the vehicle does not start. I don't know if something else is damaged or if I missed something else.
    Motor electronic start enable : no
    what will happen now?
    Sent from my SM-G975U using Tapatalk
  4. #19
    Oct 2017
    So, you were able to perform "Initial startup" with Autel? What do you mean when you say "Vin of donor ecu disappeared." ?
    I don't own Autel, could it be that it didn't do the startup procedure correctly? You did the procedure in the car and not on bench, right?
    Can you take a note of the actual values of the ME9.7 when you program the eeprom that I sent you? I am interested to see the status of the ECU (Activated, TP released and so on...)
  5. #20
    Nov 2019
    ok el vin del donor ecu doesn't take me away in autel. but when I read by ktag yes, no more checksum error comes out after reading everything. I did the updated scn and the initial start in both ways, I did it on a bench and I did it in the car but it didn't work out anyway. But the car doesn't start yet.
  6. #21
    Nov 2019
    Hi . I haven't been able to start the car yet. can anybody help me? please.
  7. #22
    Oct 2017
    I recommend that you can perform Initial startup of the ME9.7 with a better tool, like Xentry. I am not sure if Autel is really good to do this.
  8. #23
    Nov 2019
    OK thanks. I don't have xentry. I will try to buy one. and then I'll post the results.
    Is there any way to get cheap xentry? Any recommendation?
