Results 1 to 2 of 2
    ivanmihov's Avatar
    Nov 2016
    Europe
    Default Peugeot 207 CC 1.6 VTI 120 hp rich mixture fault P2178 + P0420
    This peugeot is driveing me crazy for months now
    Peugeot 207 CC 1.6 VTI 120 hp engine
    every two or three weeks mil lamp comes with faults for rich fuel mixture P2178 and P0420 Catalyst system low efficiency
    This shity car consumes oil like crazy,but i don't think that the problem is in the cat.Every time when car comes with Mil ON all live data looks good so the problem is intermittent.Fuel trims around +5%,both lambda front and rear show normal readings rear is steady 0.6 V.
    so far replaced
    pcv membrane in valve cover
    intake camshaft vanos solenoid
    Problem is that every time when comes everythink is OK in live data
  2. The Following User Says Thank You to ivanmihov For This Useful Post:
    Kfouka (1st November, 2020)
  3. #2
    Meat-Head's Avatar
    ADVERTISING:-
    https://m.ebay.co.uk/itm/Check-Engin...e-fdf2d07a7173
    also is it easy to change fuel pressure regulator
    #swapnostics
  4. The Following 2 Users Say Thank You to Meat-Head For This Useful Post:
    ivanmihov (13th November, 2019), Louislesinge (13th November, 2019)
