Results 1 to 3 of 3
    Oct 2016
    Default Repair dump eeprom and flash CAS3
    Hi, could someone help me to check and repair if necessary CAS3 BMW E60 black case.
    The car is without ignition and ELV problem.
    DTC: 00A119 - CAS: ELV Power
    Attached Dump flash + eeprom 0L01Y
    61.35-6943814-01
    5WK4 9511FBR
    Thanks advance
  2. The Following User Says Thank You to daten For This Useful Post:
    nando35 (24th March, 2021)
  3. #2
    Oct 2015
    Before start with flash and eeprom did you tried reset ELV counter (in AVDI known as SYNC CAS-ELV)?
    Oct 2016
    Quote Originally Posted by klesk1986 View Post
    Hi, thanks for your advice. The ELV counter is reset. The red flyer warning in the instrument cluster has disappeared.
