Results 1 to 8 of 8
Thread: ABS passat b6
    Jun 2018
    Default ABS passat b6
    After a dying dash board the abs coding went lost and I cant find the proper coding
    3C0614095P
    ESP 440C2 H015 0004
    WSC 05311
    VIN :WVWZZZ3CZ6E238065
    2006 BY
    engine code :BMP
    I tried several codes some of them were accepted but I get codes all drive module , and abs incorect coding .
    Any help would be appreciated.
    Feb 2018
    Bite 0013602.
  3. The Following User Says Thank You to western6089 For This Useful Post:
    ervinhod (14th November, 2019)
    Jun 2018
    Quote Originally Posted by western6089 View Post
    Bite 0013602.
    I Alredy tried that one I think , i still get incorectly coded but it accepts the code , Its a variant allroad could that be of use ?
    Feb 2018
    Yes, try 0013569 0013614 0013626
  6. The Following User Says Thank You to western6089 For This Useful Post:
    ervinhod (18th November, 2019)
    Jun 2018
    00136614 Works ok , but i have problem with parking brake i get Lamp for Automatic Parking Function: Open or Short to Ground
    even thou i dont have auto hold on this car could it be differend coding on abs ? since I tried re code parking brake still no luck loooking foward for reply, thanks alot
  8. #6
    Feb 2018
    Parking brake coding
    0 0 0 0 0 1 0 = parking brake , automatic braking NO (North America)
    0 0 0 0 0 1 1 = parking brake , automatic braking NO (The rest of the world / PR-UH1)
    0 0 0 0 0 1 2 = parking brake , automatic braking YES (The rest of the world / PR-UH2)
    0 0 0 0 0 1 3 = parking brake , automatic braking YES (North America)
  9. #7
    Feb 2018
    ABS encoding does not affect this
  10. #8
    nici's Avatar
    Apr 2017
    Have u VCDS ? This is simple JOB. First code abs ( coding helper can make coding for CAR ) , next code your parking brake.
