Originally Posted by
Rotor
64bit drivers for Actia Passthru+ XS (1 gen yellow & blue interface).
You are the only one to blame if something goes wrong, so first make backup of important data,
or test this instructions first inside a Virtual Machine or any testing PC.
Remember, i donīt have responsibility of any kind, any problem you solve it,
i have test it and it works, and it is free for you to test,, only IF YOU WANT.
Instructions (please follow the more detailed installation inside RAR file)..
No need to disable Anti_Virus, and i strong advise you to do a virus scan on this folder.
This modified drivers are only to work as PassThru under 64bit,
it will not work with Actia Multidiag software, because the interface
is not recognized, for Multi-Diag Actia-Connect use a 32bit OS.
1š install --I+ME-Actia-PassThru-XS-Driverpack-xx1--
2š install --I+ME-Actia-PassThru-XS-Driverpack-xx2--
Go to device manager and chose update drivers for Passthru+ XS,
chose ""Browse my computer for driver software""
Than click "NEXT" it will give you driver warning, press "Yes",,
it will open a red windows security about the publisher, just
click ""Install this driver software anyway""
It will confirm Updated Driver software success, next remove power from
the interface, power it up again, if asking again for drivers just repeat
one more time the process,, if you see the serial number on the driver name ,
power down, power up install driver,and is done.
If this software "I+ME-Actia-PassThru-XS-Driverpack-xx1" is not installed than
your interface will not be listed as a PassThru interface, so you must install it.
This way you will have the 1Gen interface (blue & yellow) listed as available
for any software working with passthru (under 64bit), just select it and start working.
Tested several times in Windows 7 64bit, communication confirmed with
Forscan, Xentry, etc.
Probably there is easy ways to do the same, but this was the fastest i have
discovered by myself, and works without problems.
Also i have Vas5054 working on 64Bit, check my other threads.
Password is already included, just donīt forget to press TANKS and REPUTATION,
it is a way to recognize the work that i have for the drivers you get for FREE.
