Results 1 to 11 of 11
    Rotor's Avatar
    Nov 2009
    Default -VAS5054-PassThru-Drivers-@-64bit-
    Hello to you all.
    64bit drivers for VAS5054 interface.
    This is free stuff, so do not complain if is not working with your interface..
    You are the only one to blame if something goes wrong, so first make backup of important data,
    or test this drivers first inside a Virtual Machine or any testing PC.
    Remember, i donīt have responsibility of any kind, any problem you solve it,
    i have test it and it works, and it is free for you to test,, only IF YOU WANT.
    With this installation my VAS5054 is working under 64bit as a PassThru interface, and iīm able
    to run it with Xentry new cars and other softwares that only work under 64bit.
    This drivers are not complete tested on other interfaces, so please post your results
    to confirm if work or not, and see if it need any changes.
    If you have ODIS on same installation you may have problems because the interface
    will be used only as PassThru, so you can chose it or use different
    windows installations to avoid problems.
    Tested on Windows 7,, Win 10 have conflicts.
    I have also -Actia-XS-Passthru-64bit-Driver- 1Gen VCI-
    working on 64Bit,
    check my other threads.
    Password is already included,
    just donīt forget to press TANKS and REPUTATION,
    it is a way to recognize the work that i have for the drivers you get for FREE.
    Regards
    Roturbo
  2. The Following 82 Users Say Thank You to Rotor For This Useful Post:
    Abdenour190 (31st January, 2020), adam419 (28th May, 2021), AlbertR78 (31st December, 2020), andgan (13th April, 2020), antonypaul (26th September, 2023), asam (18th February, 2020), Ass31 (14th January, 2023), attila803 (6th April, 2022), awiijiala (21st February, 2021), b4mz3 (8th September, 2020), baluballuuu (2nd May, 2021), Barajasz207 (8th May, 2021), bricolo (14th January, 2022), butch708 (8th March, 2020), Canox69 (30th May, 2022), cetateharman (19th May, 2021), chekvande (27th February, 2021), clickerfux (11th October, 2022), cobihobi (29th July, 2020), Col19 (18th November, 2019), coldshade (15th May, 2023), derbederli (13th January, 2024), dosomethingmutt (24th March, 2023), dule14786 (23rd November, 2019), dummdoedel (14th February, 2020), dyzsolt (21st January, 2023), edmondcz (27th February, 2023), edogawa (12th September, 2022), eina (29th January, 2022), electronistul21 (23rd November, 2019), Fykus9 (26th February, 2021), gruby2 (9th February, 2020), gyroplane (24th June, 2021), hutzegnom (28th December, 2021), jenya (3rd June, 2023), karol123 (3rd January, 2020), karzan1977 (7th January, 2021), kasia ovi (7th April, 2021), kleanthis sti (5th December, 2019), koko954 (22nd December, 2023), kroy0402 (6th May, 2020), lahsoumy (15th February, 2024), leonid956 (12th September, 2020), lmr1105 (22nd April, 2020), Luis Ramos (22nd December, 2021), MasterSc (2nd March, 2024), MIKELIS (17th October, 2020), mircea192 (5th July, 2021), misho2318 (18th January, 2022), mtu4u (5th April, 2024), nacar (5th April, 2022), nucleo74 (13th November, 2022), Parmar (16th April, 2024), PocketHero (15th November, 2019), pupiilov (22nd July, 2021), rafaelstrieder87 (3rd March, 2023), Raul08 (29th December, 2021), RECYK (14th June, 2022), remi_ (30th June, 2022), rmbblog (12th June, 2023), rrr86 (18th September, 2020), rs2000h (27th September, 2020), Satanic (30th November, 2022), seal777 (25th July, 2021), seba65310 (24th July, 2022), sergtroptush (19th December, 2021), skywoker (31st January, 2022), TDoc (2nd March, 2024), Team dz (7th August, 2022), thesadude (9th September, 2020), tqf (9th January, 2023), tu329 (28th August, 2021), vdiag (16th April, 2023), vrajit0ru (29th September, 2022), VtestX (19th September, 2020), w1n73rf3ll (22nd April, 2024), yakamoz (11th January, 2023), Zoby (10th March, 2020)
  3. #2
    Aug 2020
    Hi, I've installed the driver, the interface is detected as VAS5054 but when I try to test the communication with the configuration manager the VAS green light blinks a few and after that it shows "device not accesible".
    Any hint?
    Feb 2021
    hey link not working anymore please update
    Mar 2019
    Quote Originally Posted by awiijiala View Post
    I got them from just doing a Google search
  6. #5
    Jun 2021
    thanks for you help
  7. #6
    Dec 2021
    ım traying
  8. #7
    Jan 2022
    Hi will this work on odis 7.1.1
  9. #8
    Aug 2011
    Quote Originally Posted by drlefteris1 View Post
    mine fckd up after this driver installation
  10. #9
    Nov 2013
    Hi, please send new link. THX bro
  11. #10
    Nov 2023
    can i have the pass please?
  12. #11
    Mar 2016
    thanks for you help
