Page 1 of 5 12345 LastLast
Results 1 to 15 of 67
    Nov 2019
    Default Mercedes C Class 2019
    Hello guys, total newbie here.
    So i will need to change odometer on a Mercedes C Class C300d, 2019.
    What tools/software do i need to purchase that will work with this?
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Welcome to DK, I see you are new here.
    Is this your first job changing mileage or you already have experience in other cars?
    Nov 2019
    It would be first job, but most importantly i'm just interested in what the each hardware is capable of etc
    diagtech2000's Avatar
    Jul 2013
    North of England
    mate hard car to do for first job, ur better start with something easier (older/cheaper to fix) in my opinion, or you might end up with big headache after spending big $ on a new c class
    Please hit thanks if this helped you!
  5. The Following 7 Users Say Thank You to diagtech2000 For This Useful Post:
    andrym3 (18th September, 2020), autodiagdoctor (15th November, 2019), brend (18th November, 2019), jomberykaso (15th November, 2019), Quiet (4th June, 2020), sasy90 (26th July, 2020), Team dz (14th September, 2020)
    Nov 2015
    Detroit
    Quote Originally Posted by diagtech2000 View Post
    good advice hope he listens
  7. The Following 3 Users Say Thank You to BYTES For This Useful Post:
    autodiagdoctor (15th November, 2019), jomberykaso (15th November, 2019), Quiet (4th June, 2020)
  8. #6
    Sep 2019
    Is you c class a modell with needles or full lcd?
  9. #7
    Nov 2019
    Would be with full lcd
  10. #8
    Sep 2019
    For this modell you need to replace the processor in the dash. How good are you in soldering? If you want i can help you with it. I also can solder it for you. Where you are from?
  11. #9
    Sep 2013
    to replace the processor in dash?
  12. #10
    Cllau's Avatar
    Mar 2017
    where friends need me
    Quote Originally Posted by jomberykaso View Post
    yes m8...
    once the processor was replaced with the one provided you can do by OBD again every time you want...
  13. The Following User Says Thank You to Cllau For This Useful Post:
    Robert dc4 (17th November, 2019)
  14. #11
    Sep 2019
    Yes. Its easy if you make it every day. The orginal one cant be reprogrammed or erased. So put a new one in with moded orginal software and all is good. To replace is need only 8 minutes.
    https://www.youtube.com/watch?v=R1e6...ature=youtu.be
  15. The Following User Says Thank You to Robert dc4 For This Useful Post:
    keturi (21st May, 2020)
  16. #12
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by Robert dc4 View Post
    It depends which tool you use...
    Yes, if you work with dashcoder, mbcleaner...
    Elprosys has a solution without changing mcu...
    Check their site...
  17. #13
    Sep 2019
    Yes km up only. This need not so much people. And down only with a filter, which is useless, dash jumps to real km if you remove. Elprosys need to release something one year after dashcoder had a solution. They got high pressure from his customers. I have this way also all this time, but i dont see any reason to release it, as i say, its useless.
  18. #14
    figani's Avatar
    Feb 2018
    what kind of solution dashcoder use in case of BMW/FEM system...
    they donīt use a can filter...?
    Not, ok...
    how then...?
    If you write that the solution Can Bus filter is useless...
    or you mean itīs only useless when Elprosys uses a can bus emulator solution...
    and when dashcoder only a solution offers its NOT USELESS...?
    write what you want, and who makes pressure or not...
    there are more solutions then replacing mcu...
    if you like it or not...
  19. #15
    Sep 2019
    you dont understand what i wrote.
    can filter or stopper are a good solution on most cars, also at mercedes, only the latest modells W213 W463 and w222 are useless with it.
    on all other modells stops the FEM/CAS/EZS the counting but on w213 the EZS is countion all km also if the filter is installed.
    so if you pull out later the filter (and you must, mercedes is serching for it) you will see all driven km also from the time after installed the filter.
    do you still think its a usefull solution ?
    and yes there is also a solution without replacing processor but easy to copy so i will not release it.
