Results 1 to 7 of 7
    Jul 2015
    Default E81 MSV80 CMD Dump
    Hello , is it possible to modify a CMD Flasher Dump File, so that it is programmable by Kess V2? Kess recognizes the CMD Flasher signature and deny the flash. I dont have the CMD Flasher. Can someone help?
    May 2017
    kess should only read about 2mb... cmd should read 4mb.
    maybe alientech support can help you... open a ticket there. If you on clone side... forget about kess and bmw msd, msv ... (often problems there) and ktag dont do them.
    put file and we will have a look but not hopefull at this state.
    Jul 2015
    Quote Originally Posted by Lambda1 View Post
    Thanks, yes it is a clone. I just want to flash the original SW on the ECU. Someone else flashed thi ECU a long time ago and now it has to be original state.
    May 2017
    why dont u use winkfp and update ecu...
    Jul 2015
    We tried, it dont work. With original BMW AOS Ista P the same. It canceled the flash with error security login failure. I have an original aftersale access with an original Icom Next. All ECU are updated correctly, only the DME got this issue. I tried a NFS flash, the same. Security login failure.
    May 2017
    So at the end you had a problem and clone tools wont fix em.
    Jul 2015
    yep, i agree to that. I am not a tuner. The Icom and Ista us original. I m not interested in tuning, so i dont want to pay 2800 Euros for an cmd flash, only for that issue. I just want to help, but sometimes other people have to do this job 😜.
