Just one more question. Is it possible that now no more kilometers to run?
Seems to be display frozen
I really do not understand this problem. As I committed the epprom bsi was desoldered, the epprom of the dash uses the tweezers, I have programmed epprom bsi again for 290000km, then I have desolded eeprom dash and I have programmed for 290000km. Now the dash shows 420000km. I really don't understand what happens. I'm going to leave it like this, the vehicle had around 502000km so I think I had some luck. I don't want to risk more.
Thank you all and if someone could say because these things happen I will be very grateful.
check your soldering also the right position for pin 1....
if all good then you have dump corrupted...
spantor (16th November, 2019)
I'm afraid it's corrupt dump.
Is there any solution ?
where is your ori. dash dump? on BSI you have 502234Km dash dump is bad...
The original dash file is number 11 of the files that I attach. But this was extracted using the tweezers. However, the bsi file was extracted with the desoldered epprom.
Is it possible to use other dash files?
Is possible use another dash file?
Yes..................
spantor (17th November, 2019)
juste dump the eprom to a file . then run the the car to increase the milage then dump the eprom in a second file then compare those file with some kind of hexeditopr to see what changed . the eprom chip might have some sort of checksum ... data might be encoded in some kind of coding
spantor (21st November, 2019)
Shud have listened to Jombery.
Sorry, why do you say so? For not having desoldered the dash's eeprom? I did a job previously on a peugeot jumpy and directly used the epprom clamps of the dash, everything went well.
In this case it has not been so. For the next job I will desolde all the epprom and publish the files here, I will ask someone kind to help check the files in case they are corrupt and modify the mileage. I think it will be the best way to act.
Sorry for not following all the tips.
