Results 1 to 5 of 5
    Nov 2019
    Default Transit custom 2.0 euro 6 what are the options
    Hi wanted to know mine is a 130ps eu6 want to know if i can change map to the 170 also can i use a kess clone tool?
    Sep 2019
    Ipswich, Suffolk
    No to Kess clone. Upgrade can be done with KTag clone but ECU needs opening.
    Genuine Kess tool I think will do a virtual read and full write via OBD.
    Or Autotuner will do full over OBD.
  3. The Following User Says Thank You to henson12345 For This Useful Post:
    Jamaly (18th November, 2019)
    May 2018
    ECU is Sid211?
    If yes, only genuine tools.
    Wysłane z mojego SM-N970F przy użyciu Tapatalka
  5. The Following User Says Thank You to dudus8 For This Useful Post:
  6. #4
    Nov 2019
    Ecu is sid208
    May 2018
    Ktag clone do it, but check everything two times and do you need good power supply, this ECU like lots of power- about 14v 3A.
  8. The Following User Says Thank You to dudus8 For This Useful Post:
