at 64 bit did not start. 32bit All ok
Hi, I tried to install FVDI 2014 ID: F01954, after installing I tried to lunche the application , first windows an error : " mfc110.dll is not found", tried to reinstall the FVDI application gave the same error, also tried to reinstall all versions of VISUAL STUDIO C++ and the same error, so I tried to install manually "mfc110.dll" obtained from https://www.dllme.com, the error became "The application was unable to start correctly (0xc000007b), Click Ok to close the application", I have this installation on my four laptops with different WINDOWS versions: XP, Win 7 Ultimate, Win 10 all 64 bits,all gave the same error.
Please any one could help in order to solve this problem and get successfully working FVDI .
Thanks...
hussamultratec (19th November, 2019)
I run 64bit I got it installed on windows 10, just download it directly from flyobd.
Hi, I did, got the same issue
Solution for Windows 7 or W10 with 64 bit:
in the program folder to replace file 2 dll files on the 32-bit variant
1). MSVCR110.DLL
2). MFC110U.DLL
After that the program will start and error message 0xc000007b is fixed!
dusichek2012 (24th March, 2023)
