Hi all
So unlocked this with keydiy
Used correct 7945ac2319 version file
Key now shows unlocked but not keyless on vvdi2
Before unlock showed as keyless key but locked.
Any ideas ? See photo
Hi all
Tools owned -
It dosent show keyless and keyless dont work too? In worsest case flash it with diffrent fw. Vvdi probably recognize it only from text in key eeprom.
I havnt tried on car yet
Because I got this free from keyless audi a4
First it showed keyless on vvdi 2 locked
So I unlocked and now says not keyless unlocked
Tools owned -
Please upload picture of your PCB and tell what files used from KD - there is few versions
PCB is 7945ac2319 TP type
Used correct V9 version 7945ac2319 on KEYDIY
Tools owned -
Did you try programming it on car? I have exactly same part numbers PCB unlocked by keydiy and I will have car tomorrow to program but now I'm not sure if this will work. They added V9 version 7945ac2319a just in the end of October so it's kinda new.
Sorry double post
Hi no I didn't sorry
Is your car keyless go? Can you let me know result.
I still have key in stock
Tools owned -
Yes car is with keyless. I think something is wrong with this unlock file because now when I put this unlocked key by kdx2 close to kdx2 antennna to check remote signal, it send signal without pressing buttons for a short while and the other keyless go fobs which I have unlocked by different device do not behave like that. I think I'm not gonna test it on car as it's only 1 fob I have (315MHz keyless) and I will ask friend to unlock it for me with 'PCF programmer'
Sorry Plet just saw your question
No he sent me used locked key but with flat battery inside - I unlocked with Barracuda and putted new battery and the key started to blink time to time
I wasn't sure if the key is faulty or file is bad so I ordered another 2 used keys - after renew they also blinked
After that I tried with all versions on Baracuda and only with V6 after reflash key looks OK
but today I tried to program key on A7 without success - VVDI show that key is Deler key but car cant recognise the keys - Tried also Autel the same result with all 3 keys
so now must findh the right flash files for these keys
Any new info about unlocking 8T0959754K ?
