Results 1 to 12 of 12
    dimitar's Avatar
    Default Cherokee 3.0crd dpf egr
    hi can someone turn dpf and egr off please
    ecu edc16
    50w Soldering Iron
    Chisel
    Sometimes Hammer
    Jul 2019
    Everywhere
    Smile
    Quote Originally Posted by dimitar View Post
    ecu edc16
    Hi ,Try this file.
    Read this ,Pay attention "Virtual eprom into FLash"
    For the tuner the problem appears, that a readout original file is possibly not valid any more after the next starting of the engine, because the data in the flash eprom has changed.
    Valid is always the last file, which has successfully started the engine !
  3. The Following User Says Thank You to Johnwick88 For This Useful Post:
    dimitar (20th November, 2019)
    dimitar's Avatar
    Password?????
    50w Soldering Iron
    Chisel
    Sometimes Hammer
    Jul 2019
    Everywhere
    Password?????
    In my opinion, instead of writing "password ???" you would have done before giving thanks and sending me a PM.
  6. #5
    dimitar's Avatar
    I thought it works the other way around
    You send me pass then i give you thanks
    Right?
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  7. #6
    Oct 2018
    dimitar
    ecu edc16cp31????
  8. #7
    Jul 2019
    Everywhere
    You thought wrong, thanks is because I spent time for you, no if the file works or doesn't work.
    Do as you like.
  9. #8
    dimitar's Avatar
    Quote Originally Posted by tothzsolt View Post
    dimitar
    ecu edc16cp31????
    Yes its edc16p31
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  10. #9
    dimitar's Avatar
    Quote Originally Posted by Johnwick88 View Post
    Do as you like.
    Well i hit thanks for your time
    And now please stop spamming my thread
    Let others help
    Thank you
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  11. #10
    Jul 2019
    Everywhere
    Let others help
    Thank you
    You hit thanks and i sent you password and now i stop "spamming" your thread. Was easy
  12. The Following User Says Thank You to Johnwick88 For This Useful Post:
  13. #11
    dimitar's Avatar
    Still need help on this one
    Engine has no power
    Dpf is reset and removed
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  14. #12
    Oct 2018
    dimitar
    test and report
    thnx...pass pm
  15. The Following User Says Thank You to tothzsolt For This Useful Post:
    dimitar (27th December, 2019)
