Ray6K (11th October, 2022)
Greetings
Anyone have Sagem S2PM boot location? Its not the same as S2000.
My board looks like this one in attachmeng
Best Regards
2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
Official Magicmotorsport DistributorCode:FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
Official Autotuner Distributor
Official Alientech Distributor
Look at this may help pass in pm
None of these diagram suit my ecu
Anyone else?
If you can't find a solution, I always thought pulling P0L.4 (pin 104) to ground during software reset was standard procedure to enter bootloader mode on C167-based ECUs.Cpu.jpg
The pin also serves as AD4 hence traces near the flash are often used.
Tried booting pin 104, grounding with 0.5kohm and 1kohm...nothing
Tried both pinouts in attachment
ziomski (14th January, 2022)
Screenshot png attachment says 5Kohms resistor, Siemens says typical is 8KOhms.
I wonder whether your pull down resistor isn't large enough- there could be another chip attached to the line keeping the pin pulled high.
I haven't worked with these ECUs and depending on whether it's a customer's or spare I understand you may not be able to experiment freely.
You might have seen it already but attached is the Bootstrap manual. 4.1.1 is relevant. Sagem can only go off what is written there.
Hope it helps.
Tried with 5kohm, no success, tommorow ill try 8kohm
You've arranged the ECU upside down! By your image so connections will be on B and C, none in A!
Pinout is correct, i can id ecu via "obd" tool reading (by pinout connection) but have trouble boot mode read/id
Ok you might be able to use plugA H4 + plugB B4 as +12v supply pins but I use only one pin in plugC of H1. The rest can be the same.
Anyway none of all test pads in #3 are P0L4, you need the MCU pin104 or trace to flash pin24 as said above, a good pad also locates between the flash and the nearest bolt.
Works 1kohm boot on MCU pin104 (fifth from the end on my photo) and flash pin 24
Thanks everyone
Anyone got a flash read from this ecu? Hw, sw on photo
Best Regards
Its damaged ecu and it wont communicate...flash is dead and i want to write on new ecu
In case anyone needs flash 29F200BB from
S2PM-383
9642222380
9649903680
It's in attachment
Best Regards
Also a readout from flash 29F200BB but different version
S2PM-380
9642222380
9654528280
In attachment
BR
here immo off
