make sure pin 1 is in right position. in addition to this check your welding again
2014 honda civic eeprom 93c76 can some one please tell me to adjust km on this dash does the eeprom have to be read in circuit ? I have it off board and in reader but It shows no data. is this because it needs to be read in circuit? all pins have good connection thanks for any help
glenchafe (20th November, 2019)
I am using carpro tool I have eeprom in reader all pins connected and pin one in right place , no data
cant pin pin point eeprom brand is it st? or maybe amtel I just see 93c76a
If you have another chip , try to read it with your tool. To check if your tool is ok.
I read other chips no problem I wonder if I am on right chip , I know civic is 93c76 . the chip I am on is in the right side of the two piece top cluster . the one that displays actual mileage . it s a 93c76 hi located on the inside board. I installed second unit out a used car and it reads same mileage as the first one. is the mileage stored elsewhere like in the left side of the 2 piece carrier ? am I just in wrong spot? can anyone please help with the location of the 93c76 chip or a diagram of direct connection to board thanks
post a picture of dash and pcb
removed eeprom here is file if some one can help fix
old 388163
new 54123
jcodeb (19th November, 2020)
Here is your file...report
work perfect thanks again
jomberykaso (20th November, 2019)
