Results 1 to 6 of 6
    Jul 2016
    Česká Lípa
    Default Alfa 147 1.9 JTD P0191 OFF
    Hi, I need to turn off DTC p0191, the car has new injectors, DRV and still shuts down the engine at full throttle. Can anyone prevent this error from turning off the engine? Thanks!
    begi1's Avatar
    Jun 2018
    Bosnia and Herzegovina
    Quote Originally Posted by dragocz View Post
    DTC off won't fix it!!!
    If I helped you, dont forget click Thanks and Rep button. Thanks
  3. The Following User Says Thank You to begi1 For This Useful Post:
    DiegoStud (20th November, 2019)
    DiegoStud's Avatar
    Aug 2019
    How will disabling an error make your car regulate the fuel pressure any better?
    Fix your car.
    Change the fuel filter, fill up the tank.
    Im going to go with failing tank pump....
    Jul 2016
    Česká Lípa
    Fuel filter is new...
  6. #5
    Meat-Head's Avatar
    Can you put a piece of clear fuel line in or even a clear fuel filter.
    then start engine and look for michal jackson monkey
  7. The Following User Says Thank You to Meat-Head For This Useful Post:
    DiegoStud (27th November, 2019)
  8. #6
    DiegoStud's Avatar
    Aug 2019
    Gone quiet this one.
    Reckon he found Bubbles and the whole Jackson 5 in there too.
    Easy as ABC
  9. The Following User Says Thank You to DiegoStud For This Useful Post:
    Meat-Head (27th November, 2019)
