you need read full bdm file to make dpf off correctly
bFlash/Kess/Ktag/CMD Master
DPF/EGR/DTC/AdBlue/ChipTuning. ------>PM
naskochipa (20th November, 2019)
MB often ist a little son of a ******* and need open ecu to got the full file you need for jobs .
Thank you friends, Thanks and for taking the time I will do it and say if it is okay
no need full read can be done 100% in obd read
just need to be done professional
Here, try and report how it is
Friends I did as you said I downloaded FULL BDM I did DPF EGR OFF but the car still smokes what to do the sensors are on
did you reset dpf before you write file?
also clean dtc before?
push file you write and original.
obd read is enough for this ecu
is white smoke or black
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
Try this.Need all will be ok.
I'm suppose that problem is not on regen, it can be injectors...or stuck flaps. I'm mean not correct fuel/air mixture
