    Jan 2017
    Default Renault edc16 injector code
    Hi friends a lots of information of injector code lose in renault edc16 ecu when read by obd,my question its,if i read by bdm can i lose injector codes when i write modify file?,thanks
    Jul 2019
    Everywhere
    Quote Originally Posted by alfanacleto View Post
    The first thing to do is to read the injector code and then do the rest. You should check if the codes are physically written on the injectors.
    Jan 2017
    If i read on bench with bdm need to read injector codes too?
    Jul 2019
    Everywhere
    ALweys read inietors and save file. kess have a menu for read iniector code renault and save
    Jan 2017
    Ok,but ktag in bdm mode dont have injectors code read option,how can i do it please?
    May 2018
    If read/write this ECU via BDM no need read injectors codes.
    BDM is safe way read and write this ECU.
    Wysłane z mojego SM-N970F przy użyciu Tapatalka
  7. The Following User Says Thank You to dudus8 For This Useful Post:
    alfanacleto (21st November, 2019)
