Ford transit 2007 2.4d
Results 1 to 4 of 4
    Jan 2019
    Default Ford transit 2007 2.4d
    Hi, I have P0404 code on my transit and on long trips he does not go above 3k rpm sometimes, scanner says that Egr Valve is stucked open, sometimes says is stuck in closed possition, EGR is in good condition.
    " P0404 EGR VALVE POSITION CONTROL, STUCK IN CLOSED/OPEN POSITION, PENDING."
    I cleaned up the EGR valve, I readapted with Forscan but error still there. Is annoying I have power loss in load
    Someone is telling me to use kess/fg galleto to disable the egr, but I want to go for repair.
    Jul 2013
    yorkshire
    Did you test the wiring as i asked you to do on forscan forum?
    Jan 2019
    yes, but It is ok, I found some on battery but they are fine now, Back then the car sometimes did not start, do you have some schematics ? On autodata, tolerance did find anything
    Quote Originally Posted by Andr33iy98 View Post
    I would change egr. Cleaning only works sometimes. Egr common on transit
