Page 1 of 3 123 LastLast
Results 1 to 15 of 45
    Aniskey
    Guest
    Default GOLF 5 WITH VISTEON DASHBOARD
    Hi Friends
    Please, is there any solution to find pin code from visteon dashboard for GOLF5 cause i have to swap dash with damaged dump. so i can't change dump directly
    i will use VAC-COM original one. i have pin code from ECU and i need pin code for this dump to make adaptation
    Please help me if it is possible.
    thx for all
    Anis
    Moderator
    PremierD's Avatar
    Jun 2009
    08449...... I think mate ....
    Aniskey
    Guest
    pin code is ok
    thx a lot
    tiguan's Avatar
    Quote Originally Posted by PremierD View Post
    What software do you use to find dash pin code?
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by tiguan View Post
    It's called grey matter mate ... I just Know where this one is ... and how the encryption works ... sorry no easier answer ...
    Jun 2009
    hello Mr premierD, please can you change mileage of this kind of dashboard by dump from the eeprom 24c...,thank's a lot
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by aeroyas View Post
    C16 or C32 ... And what year mate .....?
    Yes as long as its before Mid 2006.....
    Jun 2009
    Is there ant eeprom on visteon dashboard??? dont think, C16 or C32 are only in VDO dash
    visteon is 95320
    Jun 2009
    but here, all cars GOLF 5 saled in morocco have dash visteon without eeprom, only processor
    Land of Rocks
    Quote Originally Posted by motorsport View Post
    visteon is 95320
    Right m8. I have tryed to change 1 2008 year with Vag Dash prog handheld machine and Vag Commander original Abritus but doesent work. Have any ideea how can be made.
    Not even the great Enigma can make it.
    calin_bm's Avatar
    near civilization
    you need to read/write the Micronas from the dash with a programmer,so you can change mileage...
  13. #13
    Land of Rocks
    Quote Originally Posted by calin_bm View Post
    My friend Calin Visteon has no micronas , only 95320 inside.
  14. #14
    Aniskey
    Guest
    right, micronas is only in dashboard VDO siemens for VAG cars after year 2006 june, visteon have 95320 eeprom only
  15. #15
    Land of Rocks
    Quote Originally Posted by Aniskey View Post
    Nobody can share the algo for calculate km ?
