    May 2019
    Thumbs up KTAG KESS KTM DIMSPORT BDM PROBE ADAPTERS Test on Marelli MJD ECU
    Here share a hot-sale auto ECU programmer– KTAG KESS KTM Dimsport BDM probe adapters.
    Reference price:
    BDM probe adapters full set is €63.99 free shipping.
    Package:
    Full BDM adapters are compatible with K-TAG/KESS /KTM/ Trasdata.
    A full set of BDM adapters (22 pieces in total) for Denso, Marelli, Bosch, Siemens:
    1.14AM00T01M Bosch
    2.14AM00T02M Delphi DCM
    3.14AM00T03M Bootloader ST10xx
    4.14P600KT04 Infineon Tricore EDC/MED17
    5.14AM00T05M Marelli MPC55xx JTAG
    6.14AM00T06M Delphi MPC55xx JTAG
    7.14AM00T07M Denso CN1 Boot
    8.14AM00T08M Denso CN2 Boot
    9.14AM00T09M Denso CN3 Boot
    10.14AM00T10M Denso CN1 AUD
    11.14AM00T11M Denso CN2 AUD
    12.14AM00T00M Delphi DCI
    13.14AM00TBAS Base Adapter 1.27
    14.14AM00T14M NexusEFI T6 Lotus
    15.14AM00TB02 Magneti Marelli BDM insert
    16.14AM00TB01 Siemens BDM insert
    17.14AM00TB03 EDC7 BDM insert
    18.14AM00T18M Magneti Marelli MPC/SPC56xx
    19.14AM00T13M Nexus MPC5xx TRW ECU
    20.VAG 1.6tdi – Siemens-Continental PCR2.1
    21.14AM00T15M Toyota NEC76F-20
    22.14AM00T16M Toyota NEC76F-26
    Test:
    BDM probe adapters has been tested on MJD ECU with KTAG V7.020
    Procedures:
    Unsolder the ECU
    Connect the Marelli BDM probe adapters to KTAG V7.020
    Open KTAG V7.020 software
    Click the vehicle logo
    Select the relevant ECU option and click “OK”
    Follow the instructions on the screen to connect to the ECU
    Remove the 0 Ohm resistor shown in the picture
    Set the ECU on the positing frame 14P800ADBO
    Connect the cable 14P600KT02 to the ECU connector according to the pinout
    Set the adapter 14AM00TBAS with pull-out insert 14AM00TB02 into the compartment of the frame and right it on the ECU.
    Notice: There is no PIN 1 on the adapter!
    Warning!
    -There is no pin 1 on the tip.
    -Line up Pin 2 of the tip with Pin 2 on the ECU
    Select the plug-in you need and click “OK”
    Click “Read” to identify ECU
    Backup the data
    Save the files separately
    BDM probe adapters read MJD ECU with KTAG V7.020 successfully
    Source: [blog.cardiagtool.co.uk]
    Enjoy!
  2. The Following User Says Thank You to Emily For This Useful Post:
    morgano (22nd November, 2019)
  3. #2
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    This is a normal price, nothing special....
    If you check in all China sites, this is the price for a long time now....
    Jun 2013
    EU
    The list of items served me well to finally identify which adapter is which one. thanks.
    May 2019
    Quote Originally Posted by morgano View Post
    Thanks for your reply. I'm glad to hear that
    May 2019
    Quote Originally Posted by Panathaole View Post
    Yes, i just think this is a good ECU programmer and share. You can buy from any website you like
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by Emily View Post
    yes, its good adapters, end very easy to use in some cases.. ex edc16..... and you can use them with ktag but and with galletto too...( with reverse adapter of course...)
