need help removing DTC p044a and p045b from w212 crd3. KESS read.
Launch X431, BOSCH KTS200, FGTech Galleto 2, MPPS , Piasini , BDM100 , KWP2000, Lexia, Can Clip, Compact C4, Omega Programer ... soldering iron
These errors are related to the egr valve. If there are problems with this valve, dpf regeneration will not work. DPF will be clogged after a while. Together with egr, you must remove DPF if you want to do this.
i can see dtc codes 0401,0402,0403,0404 etc but i can't find p044a and p045b
