Results 1 to 10 of 10
Hybrid View
    Jan 2019
    Default Vectra C 2002 Cim replacement
    Hi, I want to change Cim, I have so many issues and I am sure it is Cim.
    1)
    Donor Cim should be the same code parts as Original cim ?
    Someone told me that is some part model who is less defective
    2) If I buy reseted Cim with tech2 from ebay, Do I need donor keys or new keys or can I use my original keys ?
    3) If I buy just a key, second one can be programmed with op-com ?(Also the second key will be a scrap key)
    Thanks in advance
    Sep 2016
    its easy you just have to have same kind of cim that's easy
    Jan 2019
    On Astra H/VECTRA C cim i know that you can reset a used CIM from doner car with doner pin, then install it and then program it using YOUR keys with YOUR pin, Is tihs afirmation corect ?
    rafal's Avatar
    UK - PL
    Quote Originally Posted by Andr33iy98 View Post
    http://ukautotalk.com/vaux_cimreplacment.pdf
    need help
    now my goal is to buy xp-005
    who will help?
    Jan 2019
    Incomplete
    WALES
    If you have another identical CIM you can just swap the 93C56 eeproms and it will not need programming
    wbr
  7. The Following User Says Thank You to shooting For This Useful Post:
    rafal (24th November, 2019)
    Jan 2019
    And if different alpha code and version ? Mine is LHD and alpha code is XU, I found one RHD and DM alpha code
    Jan 2019
    and if I do not have ? I need to reset original cim and bought scrap keys that comes with donor cim, right? If I have identical Cim do I need pin code from donor ?
  10. #9
    Nov 2015
    You need pin from car
    You can buy CIM with pin or virgin/Reseted
    You can buy CIM and if its same You can swap eeprom/motorola
    You can buy CIM and read pin.
    You can use "old" keys from car.
    You can use OP-COM to program cim and keys(new keys too) but You need pin.
  11. The Following User Says Thank You to Adam871 For This Useful Post:
    Andr33iy98 (8th December, 2019)
  12. #10
    Jan 2019
    If I buy different cim I have to read car pin from psg16 with carprog, but for donor cim I need to work on bench right ? I own just carprog and opcom
