Results 1 to 10 of 10
    Oct 2017
    Spain
    Default Problems Opel astra H 1.7 cdti, 2009
    Denso ecu
    hi all
    does anyone can see my file?
    I have problems with pin code and km, i think my file is broken.
    pin code - 3279
    when i read this file appears:
    pin code - unknown
    odometer - 1,2526756275726
    Is it posible to repair it?
    thanks,
    Ziex
    Member CODEREADER's Avatar
    Jun 2010
    Did you read the file from the dash ?
    Dash eeprom is 35080 / 080DOWQ
    Sent from my Pixel 2 XL using Tapatalk
    Oct 2017
    Spain
    Quote Originally Posted by CODEREADER View Post
    I read in ecu
    Oct 2017
    Spain
    hi guys,
    any solution?
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Pin code 3279 seems to be ok....
    And eeprom seems to be ok,. With what programmer you have readings the chip?
    Try other one...
    Oct 2017
    Spain
    Quote Originally Posted by Panathaole View Post
    Try other one...
    I read with i/o terminal
    Enviado do meu VOG-L29 através do Tapatalk
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    If you open the ecu, you can see 3 eeproms...
    The first one (502) have the pin, and probably the mileage, desolder it and read it in programmer....
    Oct 2017
    Spain
    I have done this. Is the same file.
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by ziex View Post
    This is ori in bench from a 55571776 if i am not wrong.... z17tdj denso0100
  10. The Following User Says Thank You to Panathaole For This Useful Post:
    ziex (1st December, 2019)
  11. #10
    Member lynexen's Avatar
    Aug 2010
    Sweden
    Question
    Panathaole
    Hi !
    I need help with a complete EGR delete of the whole EGR sytem in the ECU-box
    ( 2007 ) Opel/Vauxhall 1.7 CDTI ( 101 Hp. )
    Engine code: Z17DTH
    Can you help out ?
    .....A little more power would also be good if it's possible.
    Can you help with that to ?
