Results 1 to 9 of 9
    Nov 2019
    Default How to remove harden cement on rough tile
    I've tiled my house using rough tiles and there are some cement stains on them..Since tile surface is a bot rough than regular tile, it's hard to remove them..I tried using heavy dirt tile cleaner and i worked to a certain extent but not completely..What Can I do to remove them completely.
    gmb45's Avatar
    Nov 2008
    park bench, hedge bottom, police cell
    brick acid, available from diy places or builders merchants.
  3. The Following User Says Thank You to gmb45 For This Useful Post:
    veraP (26th November, 2019)
    Dec 2019
    Please don't use anything like brick acid, it will etch and even totally discolour the tiles. The use of a wide blade razor scraper will work on getting the adhesive off them.. A Gundlach scraper is very good for this..
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by veraP View Post
    Use swimming pool acid. Hydrochloric acid. Used that a lot and work fine.
    Meat-Head's Avatar
    Hydrocloric acid bubbles concrete!
    Feb 2020
    geneva
    You could just use a scaler or scraper
    leotheloin's Avatar
    dublin
    ever heard of this
    Description
    Belle Clean Concrete Dissolver
    BELLE CLEAN is a liquid compound specifically formulated to dissolve built-up cement & concrete on tools and equipment associated with the concreting industry. The special de-bonding agent reverses the molecular bonding action of the cement and turns it back into a loose mix of sand and aggregate that's easily rinsed away.
    - The Acid alternative concrete dissolver.
    - A biodegradeable mixture that contains no hazardous ingredients or VOCs that can harm the environment.
    - Can be used to remove cured cement, concrete, mortar, grout or stucco from any surface and also removes old rust and oxides.
    - Non corrosive to the skin, and has no corrosive fumes to attack the lungs. It does not attack aluminium, steel or painted surfaces.
    - Non flammable substance for added safety during usage.
    - Minimum labour costs due to simple and effective procedure.
    Kalipo's Avatar
    Mar 2008
    Reichstag, Berlin
    Quote Originally Posted by leotheloin View Post
    ever heard of this
    Description
    Nem, Nem erted?
  10. #9
    leotheloin's Avatar
    dublin
    go raibh maith agat
