    Germany
    Default BMW 318d E90 EDC16c35 DPF off help please
    Hello i have an BMW E90 318d with 90KW and EDC16c35 and i need DPF off please the file is readed by KTAG over BDM frame . Does anyone can help me? Thanks and Kind regards.
    May 2017
    Let Ktag does CHKS.
    Before write delete all dtcs and reset adaption.
    didnt disconnect sensors but delete dpf.
    write file.
    run car.
    more acitivity would be nice.
  3. The Following User Says Thank You to Lambda1 For This Useful Post:
    mm04kk (26th November, 2019)
    Dec 2018
    Default DPF OFF
    try and report,
    pass in pm.
  5. The Following User Says Thank You to diags For This Useful Post:
  6. #4
    Germany
    Thank you very much for the replys i have tried now the solution from Lamda1. I have drilled the DPF and deleted all errors but Reset of the DPF adaptions was not possible DELphi says error. Then i have written the file now the car works good. If any problem becomes in the future smoke or somethink like that i will report. !!!Thank you very much!!!!
    May 2017
    You need to rest adaption with orignal file! I dont write for fun facts.
    Read with INPA and you will see two dtcs ...
  8. The Following User Says Thank You to Lambda1 For This Useful Post:
    mm04kk (28th November, 2019)
  9. #6
    Germany
    ok i will write the original file back but 1 error code comes directly when i try ti delete the error codes and he dont let me reset the adaption values. ok in the next days i will read the code out and post him here there was no description for the code.
    KIND REGARDS
