Forgot pattern lock
Results 1 to 4 of 4
    Oct 2017
    5
    Downloads
    Uploads
    Default Forgot pattern lock
    Dear concerned member, i need help with techno android spark 3 pattern unlock. Actually forgot new pattern used. Thanks
    Nov 2019
    Downloads
    Uploads
    Tecno Spark 3 hard rest
    Quote Originally Posted by alfatah78 View Post
    https://www.hardreset.info/devices/t...-first-method/
    Oct 2019
    United Kingdom, London
    Downloads
    Uploads
    I think you can unlock it through recovery email or gmail account that you can put after forgotten pattern. your password/ lock pattern will than be refreshed...
    Nov 2019
    Downloads
    Uploads
    You can easily set new pattern by tapping the "Forgotten Pattern" and proving the gmail credentials associated with your device.If not you can use Switch your phone off > press and hold the volume up + the power button at once to boot into recovery mode > select wipe data using volume keys > Select "Yes" using Menu button > press “reboot now”
