Results 1 to 6 of 6
Hybrid View
    DK Veteran brad123's Avatar
    Dec 2011
    France
    Default Bmw E46 ms43 lambda off
    Hello,
    Could someone remove lambda before catalyst please?
    ms43 max original.rar
    thank you
    May 2017
    here you go.
    Delete after cat lambda. write file. delete adaoptions and clear dtc.
  3. The Following User Says Thank You to Lambda1 For This Useful Post:
    brad123 (30th November, 2019)
    Dec 2011
    France
    A big thank you for your help, I'm testing this Monday
    May 2017
    its tested solution
    do chks, but you read with kess or similar... so should do it.
  6. #5
    Senior Member ana_11's Avatar
    Nov 2009
    EU
    Hi, Need cat off ecu ms43.
    Best Regards
    Simon
  7. #6
    Jan 2020
    Quote Originally Posted by ana_11 View Post
    here is the file to test.
    report results please.
