Results 1 to 15 of 17
    Oct 2018
    Spain
    Question problem immobilizer mazda mx-5 engine ND year 2016 smart key
    Hello friends
    I have a problem Mazda MX5 Uce dense engine P59T I can not program keys you know some way to start the car even with a special unit.
    Jan 2017
    USA ����
    First off you didn't try to provide us with enough information to understand what you already done
    what tools have you use to try to program this car
    have you scanned it OBD2 codes
    whatcodes
    what keys are you trying to program
    do you have any idea what you're doing on and on and on.............
  3. The Following User Says Thank You to sleepyrz For This Useful Post:
    Luis relsa (8th December, 2019)
    Oct 2018
    Spain
    good friendthe car went to the dealership and they did an update and erased the customer's keys
    the problem is that it doesn't let us program
    error p1260 and the car does not do the programming
    it lacks many units because it is used to run on
    25F30694-A884-4287-A56F-A60EE51D8926.jpgthe tools Autel im608, smart pro, obdline y original
    Jan 2017
    USA ����
    connect all that stuff back in........................
    why exactly is it all out like that?
  6. The Following User Says Thank You to sleepyrz For This Useful Post:
    Oct 2018
    Spain
    the client gave me everything that was taken out of the car to make it of competition connect it and I still cannot make the key
    I feel my bad English
  8. #6
    Jan 2017
    USA ����
    I googled it and first result says reprogram pcm.....
    Error Code P1260: Theft Detected Vehicle Immobilized
    Table of Contents
    Definition
    Common Symptoms
    Possible Causes
    How to Check
    How to Fix
    Error Code P1260 is defined as Theft Detected Vehicle Immobilized. This issue is usually caused by incorrectly programmed PCM (powertrain control module, also known as ECM or engine control module in other vehicle makes).
    This error code is a generic trouble code, meaning it applies to all vehicles equipped with OBD-II system, especially vehicles made since 1996 up to present. Specifications on the definition, troubleshooting, and repairs, of course, vary from one make and model to another.
    Definition
    Error Code P1260 is set when the PATS (Passive Anti-Theft System) have determined a theft condition in the system which disabled the engine, or the engine will not start from a non-PATs key attempt. This error code is also a good indicator to check the PATs for error codes.
    This code can also be set when there is a new IC (Instrument Cluster), IPS (Instrument Panel Cluster) or PCM installed, without the right programming for either of their modules if the device does not come with PATs.
    Common Symptoms
    The most common symptom for this code is the illumination of the Check Engine light on the dashboard. Also in many cases, since the vehicle is immobilized, the engine will not start.
    Possible Causes
    There are many possible reasons behind this error code, some of the most common causes include:
    Wrongly programmed PCM
    Wrongly programmed IC or IPC
    Anti-theft system concern
    Previous theft condition
    How to Check
    Try turning the key on and then leave it for a few minutes, or until the theft light stops flashing. Then start the vehicle. This will reset the system if the transceiver in the column is working.
    If the ‘Theft’ light is still on or flashes and motor turns over but still don’t start, it is possible that the transceiver in the column is at fault. The PATs module is part of the PCM, if the transceiver cannot read the key, then it will disable the fuel ignition. In this case, you will have to take your vehicle to your dealer, or to the shop of a certified technician who will use an advanced scanner to access the PATs’ security portion. They can check the keys present, which will also tell them if the keys are still stored in the memory, as well as the transceiver to see if it is reading the keys.
    If it is a case of a newly installed PCM, then there’s a good chance they erased the keys from the system. The PCM must be reprogrammed. In this case, you can ask for the help of a locksmith with a computer capable of reprogramming keys. Alternatively, you could also take your vehicle to your dealer.
    How to Fix
    As stated above, repairs for this error code usually revolves around reprogramming the PCM, which could only be done by your dealer, or by a certified technician.
    Your dealer must reprogram the computer if the computer is capable of gaining 10-minute security access to the PATs system. If you cannot access your dealer, you can take your vehicle to a certified auto locksmith
  9. The Following User Says Thank You to sleepyrz For This Useful Post:
    Luis relsa (9th December, 2019)
  10. #7
    Oct 2018
    Spain
    I do get access to pats but it doesn't let me add keys.
    how can I make virginize the pcm
    give me your skype and so we speak better
    thank you very much for all your help friend
  11. #8
    fred77's Avatar
    Jun 2019
    Quote Originally Posted by Luis relsa View Post
    definitely try disconnect battery for a minute -
    If still no luck u may need a dealer tool.
    PS nothing wrong with your english as we understand.
  12. The Following User Says Thank You to fred77 For This Useful Post:
    Luis relsa (11th December, 2019)
  13. #9
    Meat-Head's Avatar
    If it went to dealship and they erased tge keys, is it notvtgeir problem?
    have you got 1 key ir 2?
  14. The Following 2 Users Say Thank You to Meat-Head For This Useful Post:
    alclot (10th December, 2019), Luis relsa (11th December, 2019)
  15. #10
    Oct 2018
    Spain
    thank you friend
    tomorrow I will try to do those steps and I have two new keys and two keys that I had client
    PD: Jajajaja
  16. #11
    Oct 2018
    Spain
    Hello friend
    2 keys
  17. #12
    Oct 2018
    Spain
    I took off the battery and I still can’t configurate the keys.
  18. #13
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Did you check simple things like fuses at engine bay?
    Check errors in all modules.What is the message that you get when trying to program them keys?
    Dealer did an update in which module?
    Why didnot the dealer program the keys directly?
  19. The Following User Says Thank You to Stelaras26 For This Useful Post:
    Meat-Head (8th January, 2020)
  20. #14
    Newbie VictorVonDoom's Avatar
    Sep 2018
    Don't know if this is the same for your location, but this sounds like the issue we have in the US due to firmware upgrades at dealer. notice below
    NOTE! Programming of this key may be unsuccessful. Mazda has started updating the vehicles that go in for service with new FIRMWARE which does not allow programmers to work. You will need a passthrough device and an Online MAZDA subscription to program these vehicles for now. Programmer manufactures such as AD may figure out the new coding in the future.
  21. The Following User Says Thank You to VictorVonDoom For This Useful Post:
    darknezz19 (5th February, 2020)
  22. #15
    Meat-Head's Avatar
    Victordom. If your in us, what ever happened to the “right to repair” you have there!?!?!?!????!!!??
